Did my VP go too?
Well I thought the truck was running good... It sat last night and most of today and I went to start her and she fired first crank but idle extremely erratic and had a nasty lope and unloaded a mass cloud of white smoke... New injectors went in a week and a half ago and all seemed well until the lift pump failed. I'm thinking the LP took the VP too. Fuel pressure went straight to 20 psi so that's not a issue. Ran the key trick and got P1693 and then -------- and then P Done. checked for codes and found nothing.
  • Replies 211
  • Views 39.9k
  • I would not do that.  If air intrusion is suspected the last thing you want to to is suck water and soap onto the fuel stream and send that to the IP and injectors.  Besides you will never see a singl
  • For now i would clean up the connection and make sure you seat it good to see if that's the problem. I know those quick disconnects have a bad rep but mine have been in use for 6 plus years and they a
  • Marcus2000monster
    Marcus2000monster
    Let’s say eating cuz I don’t have a friggen clue how to bake a pie! Hehe
5 minutes ago, notlimah said:
If my Smarty doesn't sell here soon I'll send it out your way so you can flash it and then just send it back to me.
That would be awesome man, thanks ether way if you do sell it. And like I've mentioned it's not a huge deal if I don't get it done right away but would definitely be nice. How simple is it to enable? I'm guessing very just haven't even looked into it yet.
Easy as peach pie!
You put a tune on the truck, and then flash it back to stock.  That's all it takes.
3 minutes ago, Dieselfuture said:
Eating or baking
Let’s say eating cuz I don’t have a friggen clue how to bake a pie! Hehe:hug:
Quick and painless. I enabled mine a few years ago with @TFaoro's smarty.
I borrowed Bob Wagner Smarty years ago and flashed mine to enable the high idle.
On 4/9/2018 at 8:15 AM, Mopar1973Man said:
Which I've got a boost controller coming from China and be here on Friday.
https://www.ebay.ca/itm/361900309685
I've been had by eBay. I knew it was too good to be true. The tracking number is invalid no information given. I'm going to have the local post office check and see if they can find anything on the number as well. It's a week past the delivery date. Still no boost controller.
This is one of the reason I alway tell people DO NOT buy from eBay. Just like me I just got duped... :mad:
Not a good source for parts... Take notice its April 22 today...
Bet it'll show up around the same time as mine will. Yours will happen to be $12 more expensive. If you paid with PayPal you can file a claim and get refunded
Edited by trreed
I think it’s the seller that screwed you not eBay.
