How many KMS/MILES you got
Just hit 490,000kms on the 2001 ram an still running strong. Its my daily driver/work truck. Do some average hauling(5K-8K Lbs) from time to time. I know thats not an extreme amount of kms an the truck is under worked a lot( getting groceries, sunday cruises, ect!) lol. Just curious how many kms/miles everyone has on there trucks. Average mpg is 24.6, mix of town an hwy driving (no load)
  • Replies 47
  • Views 7.5k
    The thing that I'm learning is parts degrade over time you might not notice the changes over time but they are happening. What woke me up was the fact that I gave in on the tie rod ends and replace th
  • 225K on the body, 70K on the trans, 15K on the clutch, 35K on the motor (all in miles). Doesn't get the best mileage, but gets 15 around town and 18-19 on the highway.
  • 160K.  15 mpg in traffic , 17-19 highway. 14 with the gooseneck.
No the PO had it replaced in bfe Wyoming. The pilot bearing failed which in turn let the center of the clutch disintegrate because it was engaging off center.
What made you want to check it did you have issues noises
No noises at all but it was getting harder to shift. I started off to look at throwout bearing and saw the pilot toasted and discovered the clutch
I lost my last throw out bearing but it staring squealing. Got it replaced before any damge was done to the clutch.
Dam nice rig man!! :thumbup2:
160K.  15 mpg in traffic :(, 17-19 highway.
14 with the gooseneck. :)IMG_3029.JPG.3145f2d4ca5248c3e7ef53c037e25b1e.JPG
Edited by trreed
Hey, that's my Tahoe! Put that back!
Bet that one gets better mileage than mine, at least while sitting on your trailer.
That particular Tahoe got an engine overhaul and managed 20 mpg on the interstate somehow.  However, it sure didn't help the truck's mpg's at all sitting up there.  That rig weighed in just under 19k.
Edited by trreed
Not bad. The 5.3's are thirsty critters.Just curious, how many miles were on before the overhaul? Then I'll stop and let this thread get back on the rails.
185k kinda abused miles. Mostly towing more than it liked. Rings were very worn, and had minimal compression.
Got just shy of 100k and get around 18mpg around town.   I don't get on the highway much but would guesstimate 16.5 - 17mpg.  Heading to NY in May so I will get good highway data from that.
L8tr
D
You're scaring me man. So did you rebuilt the engine or still using it, can't remember I'm sorry. The reason I'm asking is mine only has 160 k on it and I already had to put new valve guides in the head, and also my hone marks were not as pronounced as I would have liked them to see. So I think my truck was probably abused too before I got it. I never did compression check, still seems to be running pretty good. The only other thing I can think of, engine been changed with a high mileage one or oil was never changed. Because valve guides on the Cummins should last at least half a million miles in my opinion.
I can’t tell if he’s talking about the Tahoe or Cummins?
Tahoe
He was talking about the Tahoe. I threw a derailer in there. Sorry for the confusion.
Yes.  Tahoe had 185K on it.  @Dieselfuture, I did rebuild that LS motor.  It's still going strong and its been about a year now.  Tahoe hated towing.
Truck has 160k on it and loves towing.  That motor hasn't been out of the frame.
Edited by trreed
