47RE Torque Converter Lockup Adjustment
- Replies 22
- Views 19.9k
kzimmer 8 posts
Me78569 4 posts
Mopar1973Man 2 posts
W-T 2 posts
Yeah, you're dealing with the factory programming, which is not that great. Your situation is exacerbated by your gearing. It is my understanding that Chrysler received the engine assembli
Very well...I believe you'll find excellent answers for this subject matter on this site. @Mopar1973Manhas posted a comprehensive test that directly answers this question. Take a look at
His issue isn't related to the typical ac noise, rather the tuning the PCM. auto guys with BIG injectors have this type of issue at cruise under very light load.
Hey All,
I would like to find a simple, inexpensive and automated way to adjust when torque converter lockup occurs. I am not interested in off the shelf transmission controllers. I have an electronics and industrial automation background. I am interested in hearing ideas that pertain to a DIY install and long term reliability, as well as ease of use for someone else driving the truck.
I have 3.54 gears and 35" tires. I'm fully aware what that means for my final drive ratio, and I'm not entertaining a regear at this time. Please don't suggest obvious large mechanical changes.
The truck has a lockup switch, which I generally don't use. While cruising at around 60km/h, in 3rd gear, my TPS is hovering right around the area where lockup is allowed (12% ish). There is only maybe a 2% hysteresis here, and the converter will unlock (thanks Chrysler). This is especially obvious if I set the cruise. Lock, unlock, lock, unlock. Couple this with the fact that my RPM's are too low in this situation, and a little bit of surging can occur. Really, if this trans was properly controlled, it'd be in 2nd lockup at this point. But let's not dive into that. 2nd gear might as well not even exist in this heap.
A similar but less severe situation occurs at 85-95 km/h in Overdrive. I'm not as concerned about that, I usually lock out O/D until at least over 100 km/h. I mostly want to clean up 3rd gear mid speed cruising.
So ideas. I could adjust the Quadzilla's 0-5 psi fuel percentages. If I decrease these percentages, it will force more TPS % to go the same speed. This only fixes half the problem; it'll still lockup too early, just won't keep unlocking because of low TPS. And there's the obvious side effect of increased spoolup time because of less fuel.
I could tap into the TPS analog signal, and use a potentiometer to make an adjustable voltage divider to trigger a low voltage relay, and use the contacts of the relay to open up the lockup circuit until the TPS % is higher. This would be the ideal situation where possible. It would force lockup to be delayed until higher throttle, which would mean higher speed and higher RPM. Except, this may still allow the lock-unlock-lock-unlock situation, just moved into a higher TPS range. It might even make it worse. I could maybe use another relay to allow unlock at a different TPS but that's getting a bit complex.
If there was a DC wheel speed signal somewhere, I could do something similar with a speed trigger instead. But I'm guessing all tappable speed signals are AC (or rather pulsed DC).
I'm sure there are more reasonable inexpensive solutions that I am not aware of. I'm going to keep thinking about this, and I plan on implementing something when the snow is off the ground.
Thanks in advance for your ideas.
