- Replies 47
- Views 11.3k
KATOOM 10 posts
AH64ID 8 posts
notlimah 8 posts
mopar440cu 4 posts
I just received my turbo soc and manifold blanket from Turbo Performance. I have to say they are well built and very stout. When I put them on when my new turbo comes and I will post pics. I will also
I have a heat blanket covering the exhaust manifold, turbo charger (exhaust side), exhaust down pipe, oil pan, and valve cover. This heat blanket is designed to easily withstand temperatures well abov
I run TPP blankets on my manifold and turbine housing and header wrap on my downpipe. The underhood temps are considerably lower and I like that. I can pull a slow hill at 1000°-1100° EGT's get to the
I've been considering buying a turbo blanket given the research I've done so far. Seems the claims are real where lower under hood temps and better turbine efficiency are the results. Maybe worth it for when I tow heavy in triple digit summer heat..... But I thought I'd comb the forums seeing if anyone has some experience first.
