Remaned ECM took out vp44?
- Replies 57
- Views 13.2k
bap371981 18 posts
Dieselfuture 11 posts
Mopar1973Man 9 posts
dripley 7 posts
Bap, while you are making an investment into this truck for future I want to advise you to install a new TIMBO apps. Im not saying factory apps is causing the issue, but more likely than an ECM that y
There is so much stuff we could open up with that comment snip. Like the ground wire mod. Timbo's Apps. So many other modifications that should be done to these trucks to make them bulletproof and las
I went through all that before I had it towed to the shop. The ecm is definitely the issue. We even went as far as checking harness with a meggar. That would definitely tell if there was any issue
Little background to leading up to this past week. Had the P0237 and P0112 codes with the original ECM. Replaced the MAP Sensor and IAT sensor first. Cleaned the grounds. Still had issues. Hooked it to a snap on code reader and could watch the voltage drop out to the sensors. Ordered an ECM from the number one place on the list here. Installed it. Great for 150 miles. Then got a buck and lost all throttle response. Then it came back, bucked again and then threw the P1689 code for no communication between the ECM and IP. While at the shop they went through everything using insight. Pump was dead. New pump installed. Same issue. No communication. Wiring checks out. But they are saying that the ECM could have been repaired inproperly and took out the electronics on the VP
