AirDog 150 - Finally failed
After all these years of service my AirDog as of today blew the fuse and drop the fuel pressure to ZERO. ISSPro Gauge lit the low pressure light just as I drove out of the yard. I shut down the engine the truck bump the starter to see if the pump comes on. Nope. Get back in the yard and check the fuse. 20 amp fuse blew. With it in the shop now I replaced the fuse and just bumped the starter. The pump came on and sounded rather rough. Lasted about 60 second and went quiet with a snap under the hood. Fuse blew again. I've already call Pureflow to see if I can get parts and it might be difficult being the serial number tag fell off long ago. I'm going to see if I can repair my pump and get it going again.
  • Replies 39
  • Views 11.5k
  • Mike, if Pureflow won't take care of you there is always Eric at Vulcan, he can help.   Oh yeah...... if you have time post up some pics of the repair
    Where that wave washer/spring is mine had rusted into pieces.    Seriously though. After all the years and 1/4 million miles. I'm not complaining one bit nor am I worried about exact hour sp
  • Please do on the pictures. I have my old failed one and would like to get a idea of what's in there before I take mine apart.  Sorry to hear about the pump. I think you need to have a memorial se
Just in fuzzy math assuming I kept the engine running for the last year every time I went down to Ontario for dialysis treatments for MoparMom.
13 hours per trip x 3 day a week = 39 hours a week x 52 week in a year = 2,028 hours running. Just in One Year. I've almost got 2 years counting of running back and forth.
Excessive maybe...  But fuzzy math and not accounting for the actual stop time. So now spread that over 12 years and this number might be a bit more or less. Just looking from another angle and the amount of running time in resent times. Then there might be years where its was much less.
I remember more than once where the engine was started and never really got shut down all day.
Truthfully, I really not going to complain about the pump motor failing. I think I've got my $520 dollars worth from a 12-year-old pump traveling 250k miles.
How many miles round trip on a moparmom trip?
No it’s not horrible, it just seems shorter than it should be based on advertisements I’ve seen.
I have a lower than average mph due to all the back roads stuff I do, and I’m still at 32.7. 133K miles and 4087 hours.
Edited by AH64ID
How long is the FASS pump's advertised life span? I don't remember how long the AD much less the FASS systems life span is advertised at. 85k is well short of what I expected for sure. My engine idles a lot also, but only in the winter and the suummer.
I could have swore I seen them say something about 1 million miles, because they put these pumps on semis, and someone got over a million. I thought it was on Fass site a while back when I bought my pump. And they were also proud of it how it can pump gelled fuel, obviously if fuell has moisture it it, it will just freeze and filters will plug up with gelled fuel more than likely that or they wouldn't flow very well.
1
In the beginning was 360 to 400 miles. Currently its 250 to 300 miles.
250 miles in 13 hours, worst case based on what you've said, is 19 mph average.. which is low but likely not your life average.
Even with your worst case, assuming your entire average is that low which is very unlikely, it's 13,000 hours on the pump which is better but I'm quite certain your average is probably closer to 30. (400 miles with 13 hours run time is just over 30).
A 30 mph average would be 8300 hours.
For looking at hours 45 mph average is a vehicle with lots of highway miles, 30-35 is average, 25 is low generally for excessive idle or city operations. Anything under 20 is a red flag.
I've had one tank with an average of 9.9 and it was for 300 miles with little idling, just SLOW towing and trailer maneuvering.
Simply looking at how many hours you got out of it, nothing more.
Well, then I've had several. All the years of backing trailers on the woods getting firewood. All the time idling setting up to drag logs. Like yesterday if my truck was running again driving very slow up forestry roads looking for firewood. Below 20 MPH
True its not a life average either. Still I'm sitting here thinking al the times I've fired it up and left it idling is quite a bit. That what caused my last alternator to fail was the excessive amount of idling last winter with grid heaters banging away at the alternator burned the diodes out. I can think of lots of times it was started and left to idle.
Need a pole.
Who has the most miles on a Fass Fuel Pump
Edited by GSP7
Yeah I get a few tanks a year below 25, but my life average sits just above 32 so I don't worry about it.
Do 2nd gen grid heaters not turn off after 2 minutes?
Something like that. 2 to 3 minutes roughly what I remember. Instant cancel if you reach above 20 MPH. But just firing up in a parking lot and idling to stay warm, yeah you taking the full time of the grid heaters.
Sorry the New 4g motors have a intermediate shaft and that's all there replacement motors are the new 4gs
That is a much better design, but if a wheep hole is plugged fuel will still force it's way passed a seal that is in the motor part. Unless they installed that seal with a lip/spring facing pump and not motor then it may work, assuming they used a seal and not oring. Idk I'm just thinking out loud here.
Seriously though. After all the years and 1/4 million miles. I'm not complaining one bit nor am I worried about exact hour specification of the motor and did it reach it or not. The mere fact it ran for 12 years and that mileage is awesome. I hate to say it but the AirDog pump motor lasted longer than the blower motor in the dash that is used even less.
Sorry late getting back to this post. The replacement AirDog 150 pump head came on Monday. Really simple repair. There is only 4 Allen bolts holding the pump and motor to the filter base. The new pump comes with fresh check ball for the inlet this prevents draining back to the tank. There is 2 square cut o-rings little oil on the o-ring and they stick to the pump groove. Now there is 2 fresh dowel pins for location. Clean up the face with a rag and bolt it on. Torque the Allen bolts to 90 in/lbs. Now just assemble the pump in the truck.
Now for my first-time run, I just bumped the key and it primed right up instantly. The problem is I was running 3 shims in the regulator and the fuel pressure shot to 25-26 PSI first hit. Now I had to unscrew the regulator and pull my shims out. Now after pulling the shims and bumping the starter again I hit 19 PSI right off.
Now my first trip out on Tuesday the first 100 miles was rather disturbing. The pressure was jumping all around. Down as low as 14 PSI and as high as 22 PSI. After spending the day starting and stopping in Ontario, OR. the truck the AirDog pump final settled down to 18-19 PSI and very smooth. The jumpy pressure swings stopped.
I might have another 250k mile winner only time will tell..
Good to hear you back up and running. My AD II has a pressure regulator on it. Seems I have heard many bad things about them here and elsewhere. But when I replaced my bad pump, one adjustment on install and one a little later when it settled down. Same thing I did when it was new. Just simple adjustment on the jam nut and the screw. Dont know why every one hates them so much.
I usually see the same pressure swings on my gauge after having all the lines open.
Its always good to get your truck back running :thumbup2:
Congrats, I wish when mine started to leak, airdog would send me a new motor for free. When I called them and explained my problem, they said since I wasn't original owner it wasn't covered. Then I tried to get parts from them with no luck. So I got a Fass now, airdog will never see another dime from me, because I think they should cover the product not who owns it. That's how all those part stores are able to sell you lifetime warranty junk and still make money, because most of people won't have a vehicle long enough for parts to go out.
I ended up figuring out what seal and O-rings to use eventually and rebuilt that pump myself, so now it's  just sitting on the shelf.
In all honesty my next pump with be mechanical.
