24 Valve ECM overheating?
- Replies 39
- Views 8.7k
Scottfunk 10 posts
KATOOM 9 posts
dripley 8 posts
SilverMoose 4 posts
The things we learn over the years. Some of it useful.....most of it worthless. Either way, its makes for good small talk.
Is the FASS wired in using the FASS wire loom and relay? I would guess yes since I didnt think FASS sold them without that loom. And if the relay is in place then you're loosing the fuel pump "ON" s
I would start by eliminating all the AC noise possible and doing the ground mods, damage could be already done but you'll prevent next one from frying, if that's the case.
There's something under the hood of my truck that doesn't like the heat. During spring I never had any problems, as it started to warm up symptoms got more frequent, and now that the temps are nearing 100° I can only drive for about an hour and the ecm shuts off. If I wait for about a half hour it will come back on again. The ignition system is working because my volt gauge works, and the truck turns over, but the fuel pump and my trans cooler fan that is also controlled by ecm power doesn't run. Any ideas where to start?
Edited by Scottfunk
