Smoke on start up runs rough for a bit smells like oil
- Replies 21
- Views 5.9k
Dieselfuture 11 posts
trreed 4 posts
Mopar1973Man 2 posts
Me78569 2 posts
Like my truck is doing that right now. I've got to do valve seals this summer. It drips just enough oil in the cylinder to create the blue/white smoke that smells of engine oil. Every start cold or ho
7x .010's are good mutli use injectors. they can flow enough for 500+ hp and you dont have to tune them into submission
call DAP lol. Jacob just told me what I needed.
I've mentioned this in few of my replies but now it's getting worse. It actually stumbled for a bit today when it blew some smoke out. It definitely smells like oil. I'm not loosing any antifreeze but it does seem to use a little bit of oil, I heard the oil I use (Cen-Pe-Co) is known for that so didn't think nothing of it. Last summer I did head gasket and new guides in head. So my guess is ether a seal was faulty or a guide not true that ruined a seal prematurely. I don't think it's the turbo seal because engine runs rough and if it was exhaust seal on turbo I don't think it would change how engine runs.
Is there anything else I'm missing that can cause mostly white/lightly grey smoke on start up that smells like oil. I know an injector can do this but why oil smell. If it was rings I would assume it would run like that all the time, but after initial start it's fine till it sits for a while. Definitely acts like a valve seal.
Another question, if piston is at TDC on compression stroke will all valves sit on top of piston while I remove springs and keepers, and go back together. I think I know the answer but want to be sure before I get in it.
