Quadzilla or lift pump first?
- Replies 42
- Views 7.8k
Mopar1973Man 11 posts
dripley 7 posts
LegendaryKing 6 posts
CUMMINSDIESELPWR 4 posts
lift pump always as your lift pump is pro no putting out anywhere near acceptible pressure.
Make sure you use TCW-3 two stroke oil as well L8tr D
look into fuel boss mechanical pump. wont fail like electrics and the psi increases with rpm of engine. same price less headaches.
I have looked in the forms and searched however I cant find the direct answer to this question. I dont have any gauges on my truck at this time (fuel pressure, trans temp ect..) I am looking to get the quadzilla iquad bt so I can have gauges and a mpg tune. I have a stock truck expect a bhaf and 4 inch exhaust. I am not going to race or pull crazy weights. I just want a good clean running, efficient truck. Should I get the quadzilla first or fuel pump?? Thanks for any advice.
