Power lost intermetant
- Replies 18
- Views 3k
Mopar1973Man 7 posts
int3man 4 posts
Frustrated 2001 3 posts
JAG1 1 post
When doing these, esp. W-T's grounding mods, made a huge difference on reducing AC ripple. The truck even seems to run better, and idles with a perfect smoothness. Could be my imagination, but the tru
Umm... That ground is here... This is the important one! All the other grounds are rather meaningless subsystems. (lights, horn, etc) You might do the ground wire mod and never look back to this probl
The wild part is I've seen this truck in person twice now. Once to install his first VP44 and the second time to just have dinner as they passed through Idaho. @IBMobile is a very talented man and got
I have power loss sometimes.
Sometimes going down the road empty I am at 50% throttle to do 70 mph and turning 1700 rpms this is when I have power loss.
ALSO EGTS GO UP TO 1200 AND BOOST GOES UP TO 28
When running good I am at 23% throttle to do 70 mph 1700 rpms. boost 9 ish and egts 650 ish
Things I have changed.
All electronic sensors.
Vp pump has about 20000 miles on it.
Updated the programmer and re flashed the eco in the truck.
This problem comes and goes. I can be driving down the road and all of a sudden it loses power. Then maybe the next time I drive the truck it will have power again but not always. Really noticable while towing.
somtimes it will run good for a month sometimes a day.
Sometimes it runs bad for a month sometimes a day.
When running bad it will get 6to7 mpg towing and 10 empty.
When running good I get 11 towing and 16 empty. Which I am happy with
I tow a 4500lbs all aluminum toy hauler and I will get passed by an f150 towing a larger trailer then me up a 3% grade.
Very embarrassing.
Any advice appreciated
