- Replies 20
- Views 5.9k
Cowboy Doc 5 posts
dripley 4 posts
015point9 3 posts
sooxies 2 posts
Popular Days
If you contact Vulcan Performance, an advertiser on this site, they can fix you up with whatever you need if you explain your intentions
Big line kit from Vulcan. It has everyghing you need. I am not sump person either. I modified my fuel basket for the AD and it will suck the tank dry.
I'm not sure about FASS but if you had an Airdog all you would need is a Big Line Kit (from a place like Vulcan). If i recall, the Airdog fitting that goes into the injection pump is the same size as
Hello- Newbie poster here, be gentle with me. Bought a 2002 6 speed for towing a month ago, 114K original, one owner, super clean, 100% stock. Had sat for 4+ yrs after gentleman died; I bought it from his widow, Carter block mounted LP died on way home from SLC. Local diesel shop installed newer version of Carter, but I am leery of it. So, am installing 95 gph FASS myself, with G&R dual sump. I have followed the threads here and Cummins forum, and would be OK with keeping stock fuel filter (and deleting the Carter) but don't know which fittings to use to adapt the 1/2 inch FASS supply line through it. Truck is at home (not in front of me to look at), I am in AK at work, and trying to plan and order fittings from here; will be home in a week to dive into the job. Can anyone tell me what the line fittings are on a stock 2002 fuel filter? Are they banjo and barbs? NPT? AN/ JIC? I am just trying to save myself a week + shipping time and cost by ordering the fittings now. Also, has anyone ever seen a 12mm banjo x 1/2 inch fast lock barb for sale, anywhere? (In case I wanted to increase my return line to 1/2 inch). Appreciate you all.
