- Replies 23
- Views 24.8k
JDHudsn 8 posts
dripley 5 posts
Me78569 4 posts
Mopar1973Man 2 posts
In the FWIW column when mine was doing this I could still drive it, even down the interstate. But acceleration was about 0 to 65 in 2.3 minutes. It always got where I was going. Glad it is fixed thoug
The fastest, easiest thing you can do is change out the map sensor. If you don't have time for that then just buy one and put it under the back seat with a wrench to change it if you run into trouble
Gents I need some expert opinions! I just had a p0237 code pop up. My truck is running very well and I just averaged 19.7 MPG @70 MPG on the freeway (hand math). Now I have done some preliminary research and I see it’s the map sensor.. I cleared the code and am running the truck. Unfortunately I have an elk hunt that starts Friday and I leave Wednesday morning (not much time for repairs).
What causes the code? Boost leak? Faulty connections?
If it comes on again I will be in a different state and it’s up in the mountains do I need to be concerned?
As I mentioned above my truck doesn’t seem to be missing a beat but I’ve read the map sensor can effect performance. And if I’m towing a trailer up the AZ grades I don’t want to have issues
