- Replies 39
- Views 6.8k
dripley 15 posts
Mopar1973Man 7 posts
IBMobile 3 posts
CUMMINSDIESELPWR 3 posts
Yes...You do
My "back up" fuel pump is a cheap Airtex. I have the fuse for it pulled but the relay is still connected to the ECM so no fuel pump code is stored.
Me wish me had a back up with the hurricane coming in. Cant get home, fortunately it looks like I will now get the most compared to Hickory NC. I am in Columbia SC. Damn thing looks to be hooking left
Idling in the parki g lot today and I notice 0 FP. So I dig into it and no blown fuse. Plug another relay in and nothing, hot wire the pump nothing. I have power to the pump and the ECM is triggering the relay like it should but the pump is dead. The only thing I did not do is open the cover over the gear rotor to see if something got in there. Even if something was in there the pump is not even trying to run. Any suggestions?
