3rd Gen Front Brake Upgrade
- Replies 15
- Views 15k
Dieselfuture 3 posts
dripley 2 posts
Tyler Stout 2 posts
Nutter 2 posts
I did this swap early this year, I was pretty surprised at the difference it made.
I picked up on it but didn’t have chance to respond haha. But yea it’s not as big of deal like you said with smaller tires but it’s a free upgrade if you’re already in the market for brakes and also i
Exhaust break
Hope this is helpful for y'all. For anyone that has an 00-02 Cummins with dual piston calipers up front and is in the market for front brakes, the 3rd gen brake upgrade is highly recommended. Everything is a direct bolt on. All you need is 03-07 caliper brackets, pads and rotors.. And if you have rear disc, you can do 3rd gen brakes in the rear too. The picture of the pad comparison isn’t my picture(forgot to take one), but shows you how much more surface area there is. And then the 3rd gen rotors are about an 1”+ bigger in diameter. This also requires 17”+ wheels. I went with the Stage 3 EBC Rotor and Pad kit which has drilled and slotted rotors and their Type 7000 Green Performance pads. I am still currently going through the break-in period but let me tell you, huge difference in stopping power. It takes a lot less pedal pressure to slow down and also slows down much faster and easier.
