Winter is coming - Did you change the air in your tires?
  • Replies 42
  • Views 6.2k
  • Back from 10 days of fishing in the Sierra Nevada mountains and this is what was in the campgrounds, the twins. This is at 7100' and night time lows of 26°-33°F.
  • I put a gallon of RV antifreeze in each of mine...
    I bet you all forgot to change over to winter blinker fluid so the blinkers do freeze up in the winter.
28 minutes ago, Me78569 said:
Bambi is scheduled to meet his maker in the next 7 days same goes for bambi's bigger cousin elki
Grab a beer and sit on my porch. I'm sure you can find something. Take a ride on ATV behind the house I'm sure you can find something. Heck everyone always gets excited watching the elk across the road from my place and drooling. Joe Albertson as in the grocery store owner has a place across from me. Personally, I'm not the hunting nut.
I got a job where I have to use 4wd a lot. Would it be less likely to give me trouble and if I change out the vacuum hoses? They are original.
On my 1996 Dodge Ram 1500 I'm planning some time this winter to do all fresh air brake tubing to replace all the vacuum lines. I've got vinyl tubing for now but engine heat does weird things to the tubing. Now that I've studied it a bit more I can clean up the vacuum routing a bunch. Way too many long runs and too much ran on a single connection which is a poor design which I followed. Being there is like 6 ports in the manifold I can separate a bunch of this and route it away from heat.
Yes, for a trouble free 4 wheel drive winter experience change out the original vacuum hoses.   Be sure to install only Mopar factory winter hoses.
So you need to buy those from Alaska right?
There or on eBay from a little store in Quebec for our Canadian friends, eh.:canada:
I been to that store it's called the 'Hoser' up in the tundra at the end of main street in a shack in Yellow Knife. $49.99 a ft.
I like the meat, I could care less about the hunt.  I would be A-OK shooting a Elk tied to a tree.
Elk hunted me down when I stared too long at a female. Was in the Canadian Rockies and he was huge. He stopped running me down when I fell over a small stump. :shrug:
Just don’t shoot one down in a hell hole where you have to bring your cooking gear to the elk.
He was laughing to hard to chase you anymore.
Here's a coupon if anybody needs it.
Major Blinker fluid shortages this year..... too many folks in the United States are staring at the Mopar1973Man forum.
In case your find the muffler bearing worn out...
