An additional fuel filter
- Replies 14
- Views 2.8k
Mopar1973Man 3 posts
JAG1 2 posts
015point9 2 posts
Bullet 2 posts
I run the racor brand with the see thru bowl on both trucks. I like them because they are designed for the suction side and I designed a skid/ protection plate that swings out of the way when servicin
We'll see if this link works. See if any of these fit your description https://www.google.com/search?q=DIESEL+FUEL+FILTER+WITH+SIGHT&rlz=1C1CHBD_enUS753US753&tbm=isch&a
I have exactly what you described on my boat's fuel system. It has a replaceable metal spin on filter down to 5 microns or so and then a see through plastic bowl with a drain valve screwed on to the
Thinking I (want or need) more fuel filtering. Right now no problems with airdog 95 or 100 (cant remember which) going from tank to airdog directly to vp44. 2 or 3 micron I believe. Want to install a 8 or 10 micron before fuel goes thru airdog filter.
In late 90's or 2000's at work some of our trucks had water and fuel filter that was plastic see thru, that you could just look at and see fuel drizzle down into plastic bowl or not. Getting a visual on fuel came in handy to see if any fuel problems going on. Like out of fuel, pump not working etc. ( I do have a fuel pressure gauge) never had a problem with cracking or leaking.
I'm trying to find a system like that and small enough to fit up under bed near cab, next to airdog.
Anybody know of a filter system that's fits that description?
