- Replies 38
- Views 8.5k
dripley 7 posts
NIsaacs 7 posts
Mopar1973Man 5 posts
dave110 5 posts
Ive ordered spicer UJ and i havent ordered bearings as mine are ok but i will keep in mind the recomendation cheers
You must have one heck of an arm, my two handed sledge is only 8#, I doubt I could even swing a 6 with one hand. This is what I use for u-joints, I posted these a while back on another sit
A leaky rear main will keep the the underside oiled with no spraying involved, manually that is
One of my front axle shaft u joints failed today passanger side its clonking pretty bad in 4x4... can someone help with part numbers or give me a part number on rock auto to order as there is a few sizes it has a dana 60 front end its a 99 2500. im in the UK so its easy to order from rock auto or any other recommendations on who to order from. Thanks
