Extended crank to start
Developed a new issue. Usually my truck will start with half a revolution. It has started taking 4 sometimes more to start. What’s going on? No codes truck runs good. Good fuel pressure.
  • Replies 151
  • Views 28.7k
    Never hook the fuel pump to the battery. Hook it up in the power stud in the PDC.    I wish both AirDog and FASS would remove that from the manual. That is the dumbest thing I've heard was t
  • So this issue you're having. Your title says extended crank but later on you say slow crank. 2 very different things. Which is it? I've had extended crank issues twice. Once was an IP that was just wo
  • That's as close to stock as you can get.   Make sure they are the Bosch RV275 and not some cheap knock off junk.  I bought mine from DAP last spring.
1 hour ago, Marcus2000monster said:
So the issue is not within the grid heaters and it only starts hard when the engine is cold. I think we’re getting this narrowed down. Headed out now with the scanner.
IAT was 143 and ECT was 159.
For hot temps that's fairly close, withing 10* Hot is normal for me. Cold they needs to be the same. Often times the IAT sensor fails within specification and you get hard starting. A good way to test is to plug the truck in and she will fire right up. The issue is more commonly seen in the CR era, where guys have these issues because the ECM will not throw a code for that.
I should have clarified that I was speaking of a cold engine, 1st start of the day, and the temps matching.
Dude... your iat (moparmanswitch)fooler is on, flip it to off and test it on cold engine. :punish:
But I might be wrong.....
O does everyone turn they’re switch to the off position when shutting they’re truck down?
I leave mine in mpg mode unless it's really cold out and I want grids to stay on longer.
Yea man, if you’re leaving your switch in MPG setting then you’re telling the IAT sensor it’s warm out and no need to cycle grids, which is why your WTS light is going out so quick and why it’s stumbling a little bit when it’s colder out.
Mine will do the same and it’s not even as cold here as you’re seeing. I’ll typically turn mine to MPG after the first start of the day and leave it like that all day, then back to off after last shut down for the night.
WEll thanks guys I think that should solve the problem! And wouldn’t you know the next problem is here! My alternator fried!
Well, that's interesting stuff on the IAT fooler. Makes perfect sense but I wouldn't have thought of it. If it's not already spelled out in the instruction manual for the fooler it should be.
Stupid grids.....
But better than glow plugs i guess
Never had glow plugs except on rental equipment. I believe they use old railroad truck springs in the switches. You need gorilla fingers to turn and hold them in the on position to heat up.
I'm not sure it's explicitly spelled out to explain what we're talking about, but it's tricking the IAT's and ECT's to thinking they're hotter/colder (as applicable) then they actually are, so it'll have change things in that sense.
I understand that part. What I'm saying is there should be a simple side note saying fooler must be turned off to start in cold weather or something like that.
Something right like what your saying here.
Exactly... The IAT will affect the pre-heat cycle but the battery temperature controls the post heat cycle after the engine is started. If you leave the MPG mode up on a cold start the grid heater will not fire. Then after it starts it will run grid heaters. Now the strange but true you can have 195°F coolant and IAT at 90°F and the grid heater will still fire post heat. Even though the IAT could be fooled to 143°F still the gird heaters will fire on post heat. This is the battery temperature sensor feeding this data.
So how do we deal with that. I don't want them cycling after the truck is already running.
Edit
I guess it's back to toggle switch idea
Edited by Dieselfuture
FWIW my toggle switch has been on for over a year now with zero issues other than the 2 hidden codes I never see. I love it. Turn on, pre heat, start, turn off, save alternator.
@IBMobile Ahem.
 I now understand switch operation be done in the following sequence? Key on, start truck, switch to 6 cyl, let warm up, switch back to mpg, drive truck, shut off, switch off. This is the way our discussion has led me to believe it should be operated is this correct? Now I remember that Mike recommends switching to your desired selection before starting truck. Does this mean you should cycle grids then make your selection and then start?
Three words. TELL US HOW! :sofa:
57 minutes ago, Marcus2000monster said:
@IBMobile Ahem.
I select whatever setting I’m going to use before I start ifnim going to use 6 or 3 cylinder modes. If I’m going to use mpg and truck is cold (like sat overnight cold) I start with the switch off then select mpg as I get driving. I then leave it in MPG the rest of the day.
