- Replies 22
- Views 4.7k
Mopar1973Man 3 posts
Ed ke6bnl 3 posts
BBHD 3 posts
puglyfe 3 posts
The option "shift on the fly" is advertised with or without CAD (center axle disconnect). You will need to look at the axle to see if there is a CAD unit attached. If you do not have the CAD - end o
OR - recognize that the front wheel hubs sometimes have problems - and if you put in a "Free Spin" kit....you just leave the hubs unlocked when you want 2L. I did the free spin installatio
Cost me $1300 about 5 years ago. I was looking at spending 40% of that to re-do the hubs...and I figured that if I did the free spin conversion, I wouldn't have to worry about the issues for a VERY V
I'm looking to add a 2wd low setup to my 2002 HO 6speed. From what I found so far there are 3 kits available, BD, Pacbrake, and Posi-Lok. Is there a preference of one over the others? is there anything else I missed? Two are vacuum based and the other is a mechanical setup.
I want it for trailer maneuvering, taking some stress off the clutch.
