- Replies 19
- Views 6.1k
Mopar1973Man 4 posts
Bullet 4 posts
Dieselfuture 3 posts
kzimmer 2 posts
Tape a small diameter tubing to a shop vac hose and use that to suck up anything that fell into smaller areas. It won't hurt to vacuum up dirty oil with it...... just get out all you can. I like soft
That matting does nothing for sound. It does make great mouse bedding all over your engine. Then if you have an oil leak it soaks up oil and the sags down on the engine. It is great for dumping tons o
They are plastic thread on fasteners actually...
I was replacing my injectors yesterday and when I took the valve cover off one of the bolts ripped the insulation and that crap went everywhere.
I know some fell into the engine and I tried to wipe what I could out by number 6.
How screwed am I?
