What NV5600 fluids are yall running?
I normally run royal purple, 5 quart capacity plus 1. I'm gonna run some pennzoil synchro mesh for my new re build break in then change over to something different. So I know to run synchro mesh, but I've heard of guys using redline and other stuff.
What is y'alls recipes?
I haven't seen a whole lot of synchro mesh options out there.
  • Replies 41
  • Views 20.1k
  • G56 has always been ATF+4 from Dodge/Ram and GL-4 from MB. So nothing has changed there since it’s release.    NV-5600 only gets ATF+4 recently from Dodge, LONG after any warranty period. De
  • Tractorman
    Tractorman
    I have used the Pennzoil Synchromesh for the life of my NV5600 transmission - 308,000 miles so far.  It has never had any shifting problems and has never been disassembled.  I have replaced the rear s
  • Amsoil, thats what I ran in my 05 when I had it. Amsoil goes in the 5spd too. Shift quality is good and the right stuff for the job.
Let's say that Dodge Dealer is now filling both NV4500 and NV5600 with ATF+4 transmission fluid. Since neither fluid is no longer manufactured.  If your worried about specs then Dodge dealer choice of ATF+4 is telling me there is not much to the spec other than its got to thin fluid for shift quality.
I have always run the Penzoil sychromesh. Sure are a lot more thoughts on what to run in them these days.
Red Line 75W 80 synthetic is the best performing transmission oil I have tried by a long shot so far.  I decided to use it in the wife's truck since it has a fussy 3rd gear synchronizer.  It REALLY improved how the wife's truck shifts through the gears.  The Amsoil MTF works well too but is a bit thinner in viscosity.  I mixed the Amsoil MTF 50/50 with SAE 50 synthetic transmission oil in my truck which is not real cold weather friendly on the first start of the day but once warmed up or in warm weather works very well.
Peter aT Southbend said Red Line MTL. The other Red Line isn't the one that one is for the NV4500 not the NV5600
Edited by Mad Bomber
There's lots of different opinions floating around out there and here, I've read. From all these oils I really haven't seen a common trend on what everyone is using, it usually 3-4 different oils and biased.
I just get so confused lol. So I figured I'd make my own thread, and since I trust all the knowledge on this site, maybe I could get on board with a brand/weight.
So far I only can come to the consensus that synchromesh oil is what I should run. But I'd like more options... and it's hard to find sometimes.
Also gonna do the same thing with t-case. But I know it's just atf so that's pretty simple. Just gotta choose a brand, lol.
It looks like cost is not a real big issue due to low miles traveled (140k) For me it is, plus mostly they are towing miles. I use 15/40 diesel engine oil, 326k original tranny. I would not use any ATF. I also never overfill. I change every 36K miles. Keep it clean and full and these trannys go a long time.
Any ATF+4 for the t-case is fine. Be sure and pull the fill plug first and make sure it is not overfull or discolored by tranny oil. The biggest down fall of any manual tranny with 4x4 is running them low, due to leakage into the t-case. On a 4x2 any leak from the tranny is obvious.
I've ran the Amsoil Syncromesh in my 05 since it had 15K miles on it. It has 140K now and shifts great.
3 minutes ago, Dmaney said:
So is a trashed trans.
And that will really cost you a lot more.
15 minutes ago, Stanley said:
What are you running @Mopar1973Man ?
Mobil 50 SAE GL-4 Synthetic Transmission fluid. Same stuff used in Eaton Fuller 10 speed transmissions. I'm at 110k miles and still going... No shift issues even with winter temperatures down to near -30*F and shift like butter. Be aware 50 weight oil is actually 90 weight Gear Lube much thicker. Like 75w-85 for the NV4500 is like 10w-30 engine oil.
Image result for oil viscosity
Image result for mopar1973man mobil 50
Have to remember @Mopar1973Man is running a NV4500, little different animal. That being said what he's using works great for him. Just personally I'll pay 4 or 5 bucks a quart more for the fluid that was made for my trans. If $20 makes or breaks me on a trans oil change every 100k then I probably shouldn't own a Cummins.
Don't have to warranty any NV4500 or NV5600's. Seriously think they care? As far as the G56 there are lots of mixed reviews on what oil "should" be in them. Seems I've read where Mercedes and Chrysler don't see eye to eye on that one. But I like my old second gens and will cross the G56 bridge another day.
