Question
What could be a possible cause of a long crank when the motor is hot?
Starts great when cold
Fuel pressure constant 17 psi
Cranks great
Thanks in advance I won't have internet access till first of the week
  • Replies 31
  • Views 5.6k
  • Usually threads aren't off topic till Mike posts a picture of one of his girlfriends.
  • Keep it simple.  Doing an adjustment is a lot easier than doing a lot of rewiring. If that doesn't work you might try this.
  • He met her in Ontario when he was riding his bike.
2 hours ago, kzimmer said:
Thanks @IBMobile, I've been looking for a wire that's switched with engine running. I'm going to use it to disable the grid heaters through a 200 amp solenoid I got off of Amazon while the engine is running. I think it's the simplest way to protect the alternator from the grids. Sorry to get the thread off topic.
Usually threads aren't off topic till Mike posts a picture of one of his girlfriends. :burnout:
She can probably build a deadly dream catcher.
Wait I thought that was mike
Yer close.... he is a refugee from LA
