Oil Pressure Running High
Hi All, my truck has recently presented a new issue.  The oil pressure reads rather high, mostly all the time on the gauge on the dash.
I'm thinking the oil pressure sensor could be failing, but I would rather make sure my oil pressure is correct.
The bad news is I'm about 200 miles away from home for the next week and don't have my service manual with me (doh!).
The good news is I have access to tools so I may be able to solve this while I'm here.
I have a mechanical oil pressure gauge and was thinking about testing the pressure first before making assumptions, does anyone know if anyone posted an article about how to properly run the mechanical oil pressure test on my 2001 5.9?
Also if it is the sensor does anyone have any thoughts on the best replacement part to get with?  Are there any good lower price aftermarket units or...?
Thanks in advance for the help.
  • Replies 62
  • Views 17.4k
  • Ed ke6bnl
    Ed ke6bnl
    this is the sensor I put in my 98.5       $16 prime and worked fine I paid over $100 for the previous one. https://www.amazon.com/gp/product/B01A0RH8O8/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&
  • You might ought to look at your sensor harness and be sure it is a 3 wire sensor. The 02's have a one wire switch. Just not sure whether Dodge made the change on the late 01's or the early 02's. Mine
  • Dieselfuture
    Dieselfuture
    I was going to suggest changing a filter, just never know. What filter are you using currently?
1 hour ago, leety said:
Looks like it's 44 ft lbs.
I like to measure stuff, just because.
Nothing wrong with that. Did alot of torquing on the head gasket replacement. Just never torqued an oil pan plug.
10 minutes ago, Mopar1973Man said:
@dripley
Oil pressure relief valve plug not the oil pan.
Pretty sure he asked about the drain plug.
2 hours ago, leety said:
Can you tell me the torque setting for the drain plug please?
You guys crack me up.
This just in.
Motor @ normal operating temp getting just south of 30 psi at idol and about 73 psi at about 2k rpms.
1 minute ago, leety said:
This just in.
Thats in the filter head?
Seems about right.
How old was the oil you changed?
Edited by AH64ID
Good thing you didnt change gear ratio and swap to higher bar injectors for that fix.
 maybe the straw to blow off valve was plugged and new oil cleared it out.
On 6/5/2019 at 4:00 PM, AH64ID said:
Still not seeing how a filter can increase pressure after the filter. Not sure it’s physically possible.
Filter itself can't increase pressure it will simply go into bypass mode and continue to flow. I totally agree...
She asked about the drain plug :-)
Well it seems the display on the dash is reading a high pressure when the engine is at full operating temperature.
When measured with a mechanical gauge the pressure seems high 75+ when cold and fine 30-73 at normal operating temp.  These measurements were taken pre oil change.
I pulled the plug and filter to drain overnight yesterday.
I will measure again after I put the new oil in to see if the pressure is still high when cold.
I don’t have my records with me to see when I changed the oil last, but I think it is about due.
So what should I check next to figure out how to fix the incorrect reading on the gauge on the dash?
The sensor comes to mind, Could be failing but not enough to trip a code.
When I don't have time for an overnight draining and a little overdue, I like to pour an extra quart of oil thru the engine with the drain plug out. Wasteful perhaps, but the cold oil running into the dirty warm oil, you can see pushes more dirt out. I do it every once in awhile.
Rotella 15w40 & on cold start with Autometer gauge at oil filter head I have 38psi idle and 85psi 2000 RPM. Hot idle 30psi idle, 75psi 2000 RPM. Factory dash gauge reads a few pounds lower but seems to mirror movement.
Be aware of the dash gauge its not exactly a accurate gauge.
Take note this video is really old being I've not used a Edge Comp in a long time.
trippy
@Mopar1973Man  Correct me if I am wrong but this is on your 02 with the one wire switch and not the earlier years with an actual pressure sensor. My 02 is the same way. I wonder if the earlier years react the same way.
2 minutes ago, Mopar1973Man said:
It is a pressure sensor. Even though its a single wire.
I realize that but the gauge would receive the signal differently would it not? Ours just closes a switch when pressure is detected then the ECM takes over using rpm and ect for the pressure reading. The early ones actually read the pressure and send that on to the gauge. Just makes me wonder it the early models are wonky like that.
02’s (and anything after) don’t have pressure transducers, just pressure switches. The dash gauge is 100% fake.
Edited by AH64ID
Not exactly.
It is a pressure transducer but just a 1 wire. It does have a variable resistance to ground. It is NOT a switch with open (infinite ohms) and closed state (0 ohms). ECM is creating a weird value from that which follows some weird software math.
Pressure transducers have to have more than 1 wire.
Pressure switches can have 1 wire thou.
It’s a well known change from 02+, and even some earlier models have software upgrades that treat the transducer as a switch.
