- Replies 31
- Views 10.5k
beren 13 posts
Mopar1973Man 7 posts
kzimmer 4 posts
JAG1 2 posts
Popular Days
@beren, my perspective is different than most regarding the lift pump fuel pressure minimums. My understanding of the VP44 pump operation says that your 10 to 14 psi at the VP44 pump inlet is fine.
Too low of fuel pressure. Should of been 14 to 20 PSI to keep the overflow valve open. At 10 to 14 PSI the overflow valve isn't open enough to keep it cooled and lubricated. This is a reason why VP44
Yeah I'll see if it changes, I'm not currently driving more than 50mi from home, but I guess I'll change it asap if I get some side work hauling trailers. Sucks I just spent $1k on tires, harmonic bal
This week I've had a few times where I'm doing around 65mph on the highway and I hit the pedal to accelerate, and nothing happens. The engine sound might change a tiny bit but I can't accelerate at all. if I mash or get off the pedal and back on it doesn't let me go any faster. Quadzilla doesn't show anything strange, except that my throttle position changes with the pedal push. If I downshift for a sec and then go back into 6th everything is fine. Today I pulled the codes for the first time and got P0216. I'll have to check and see if it comes back. There was one odd thing 2 weeks ago when I changed the fuel filter, the next day it took about 6s to start vs the near instant it usually is. I put 2-cycle oil in the fuel for the first time in a year or so as well, just before it started acting up. I really hope the VP isn't dying, as it's only got 56k miles on it. I bought it Aug 2012 and don't drive it a ton until recently. It was BlueChip's Premium Upgraded HO pump. Fuel pressure has been 10-14psi.
