- Replies 46
- Views 10.3k
Mopar1973Man 15 posts
AH64ID 6 posts
GSP7 6 posts
NIsaacs 5 posts
The standard in stock Napa thermostat is Motorad for the 180 or 190. They offer a 190 Safe-T-Stat special order, it is the fail safe type. They also offer a stainless steel one, special order.
Anyone that works on their own vehicle knows this. My point is, oem has different specs than the aftermarket, they will fit and work. Aftermarket will usually fit and might work.
I don't know who the vendor is, but whoever it is they will manufacture to Cummins specs. You say the 2019 is different but without a part number it is hard to say. That t-stat looks like a 12 valve s
Most Helpful Posts
I left the factory 190°F thermostat for a Gates 200°F and gained performance and MPG.
Some quick guidance on the Quadzilla. You will see about 204℉ to 210℉ coolant temperature on average. The bonus is the oil temperature measured at the test port on the oil filter head, you should be f
I know the good Cummins thermostat is expensive..... Maybe not
What Brand is a good reliable thermostat . genos sells the Gates -33915
Edited by GSP7
