Thermostat... just a good one
I know the good Cummins thermostat is expensive..... Maybe not
What Brand is a good reliable  thermostat . genos sells the Gates -33915
Edited by GSP7
  • Replies 46
  • Views 17.2k
  • The standard in stock Napa thermostat is Motorad for the 180 or 190. They offer a 190 Safe-T-Stat special order, it is the fail safe type. They also offer a stainless steel one, special order.
  • Anyone that works on their own vehicle knows this. My point is, oem has different specs than the aftermarket, they will fit and work. Aftermarket will usually fit and might work.
  • I don't know who the vendor is, but whoever it is they will manufacture to Cummins specs. You say the 2019 is different but without a part number it is hard to say. That t-stat looks like a 12 valve s
Most Helpful Posts
    I left the factory 190°F thermostat for a Gates 200°F and gained performance and MPG.
    Some quick guidance on the Quadzilla. You will see about 204℉ to 210℉ coolant temperature on average. The bonus is the oil temperature measured at the test port on the oil filter head, you should be f
6 hours ago, Mopar1973Man said:
I've been using NAPA thermostats no issues.
Is that a "fails open " type?
Never had a failure yet in 17 years of using NAPA thermostats. I've got like 3 of them on the shelf of used ones for spares.
I've got 1 Gates thermostat that is junk. Wild up and down temperature swings. Not a NAPA but RockAuto.
I just changed coolant and flushed the system yesterday. went to Napa to pick up a new thermo and 3 gallons of green, my system looked as clean as day one.
Opened up the thermostat box from napa and it was the same as the one I took out, stamped motorad. Last time I changed thermostat was in 2011, never had an issue and that one and it came from
Orielys
I also dilute antifreeze with well water and my system is clean, no scale build up
I have no loyalty on t stats. I just put what ever is available.
Cummins or nothing for me.
I won’t put a NAPA anything on my truck. Too much junk over the years, heck I won’t even buy shop towels at NAPA.
Lots of threads across the forums about issues with just about any non-OEM thermostat.
who manufactures these napa thermostats?  Brand/company?
IIRC they list a couple different makes online
I had major issues with my Napa 180, went to a Cummins 180 and all is well. I haul heavy, in steep country, in hot weather. Driving around empty, the Napa 180 was fine. Note the difference in design of the Cummins (far left) and the Napa (far right) these are both 180. The middle one is a 190 but not sure of the make. Be sure and click on the pictures and blow them up for a real good look.
Edited by NIsaacs
add content
I can tell you that Cummins and Mopar do NOT produce any thermostats and will randomly change manufacture at the drop of a hat.
That is NOT a current Cummins thermostat they have changed again. Out of date...
New Cummins on the far left (2019). Then the old Cummins on the right. (2002). New Cummins thermostat failed right out of the box. Excessively cold.
What is the part# of your current Cummins t-stat and temp? Mine is #5292742 180* bought in 12-18. If you do some research you will find that Stant and Gates are the same as my Cummins#, they will say "OE Type". Napa/Motorad will say "OE Temp".
If you look up Napa's old number 457180 it will show as " OE Exact"
https://r.search.yahoo.com/_ylt=Awr9Fq5eKUhdS3IAwBZXNyoA;_ylu=X3oDMTByb2lvbXVuBGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzcg--/RV=2/RE=1565039070/RO=10/RU=https%3a%2f%2fwww.napaonline.com%2fen%2fp%2fMRD457180/RK=2/RS=EwtqBSBP0ydFcDMA6xvErz6bx80-
In my use, the Napa did not work, the Cummins does.
I'm not sure at this time I can find out from @mr.obvious. His was a 190°F bought in May of 2019. Purchase from Kenworth dealer in Ontario, OR.
My point is that neither Cummins or Mopar produce thermostats. They change manufactures when they wish at any time. There is only a few companies that actually do produce thermostats. What they are listed as doesn't matter either being NAPA doesn't produce thermostats either. NAPA changes manufactures at the drop of a hat as well. It more about who made the thermostat than the vendor that sold the thermostat.
So far no one had been able identify the manufacture of any thermostats and just chase brand names.
I know that your point. But... Who manufactures the thermostats? Being that even Cummins thermostat I've seen is different and never the same. Like yours is 2018 and standard style. Then 2019 went to a different design all together.
Again WHO is manufacturing the thermostats for Cummins and Mopar? This is the only thing I want to know. Because neither Cummins or Mopar manufacture thermostats.
I don't know who the vendor is, but whoever it is they will manufacture to Cummins specs. You say the 2019 is different but without a part number it is hard to say. That t-stat looks like a 12 valve style. Maybe it was packaged wrong....
Why I'm asking for the manufacture than the vendor because then you can go directly to the source for a the thermostat and most likely get a better price and still get a Cummins thermostat.
Cummins, Mopar, NAPA, Autozone are just vendors that sell what is put in the box and know nothing about what is in the box. I've ask at the Dodge Dealer for manufacture info and they are clueless like usual. Still in all there is only a handful of companies manufacturing these thermostats and you should just go directly to the manufacture and skip the logo'ed box.
Bottom line sounds like a crap shoot to some degree over the years, and guys saying "cummins boxed thermostat only" is the best hands down appear to be wrong since they change makers
So labeled box aside,, what manufacture seems the best?...motorad ? :cool:
:doh:
I want the fails open type
Here is what is listed for my '99 .....
Looks like I want the top one or bottom one .
What is the jiggle pin one at the bottom? Is that a safety too , and looks like the top one is Stainless steel?
https://www.napaonline.com/en/search?input-q=I+Don't+Know&q=N%3D2500005%2B2600501%2B2802469%2B10199900%2B5002000%2B5002200%2B200220100%2B402203300%2B599999900%2B50600000%26Score%3D0.9&text=thermostat&indices=UI&keywordInput=thermostat&referer=nol-veh-conds
Edited by GSP7
Cummins might change manufacturers,  but the specs likely don't vary from mfg to mfg....
Either way, not sure how it can be wrong when the forums are full of failed/improper operating non-Cummins units and I haven't read any of those issues with OEM thermostats.
Non-OEM is a crap shoot, not so with OEM.
Umm... Both Cummins and the new one was dead in the box... Hmmm... But this is NOT a OEM on the left being OEM is on the right. Both are Cummins thermostats. Also people are quick to complain about something but rarely give praise for something that does work. Being I've been using NAPA I've not had one failure YET. All thermostats have worked without an issue. I will give NAPA thermostats some kudo's.
