- Replies 78
- Views 9.4k
I highly recommend and use ONLY triple disc converters in every Cummins application. You MIGHT be able to talk me into running a single behind, say, a BONE STOCK 12 valve, but only because of the line
That's 10 minutes from my house where I got a degree in construction management and where my wife retired from. I had a BIG piece of cardboard over the dirt with a smaller piece of plywo
Matter of fact thats what I did the last time. With idling I have been doing in this heat the 1200 miles a quart shrinks to 700 or 800.
After testing and conferring the consensus is my truck needs a new torque convertor. The truck is used 95% of the time towing a 8,000+ pound 5th wheel and the transmission is basically stock. Which brand is good and which type, stock or billet? Should it be a single or triple disk? High or low stall speed? Any thing else you can think of.
