- Replies 16
- Views 15k
Evan 4 posts
Mopar1973Man 3 posts
Dynamic 3 posts
IBMobile 2 posts
Flexplate to crank: 105 lb/ft
IBM, I agree I found both of the different references you found.... I think the bolts are M12. Need to know the class of bolt. (and materials to be fastened) Metric 12.9 (s
The converter to flex plate bolts torque to 38 lb/ft.
When looking up the tightening specification for installing the bolts that hold the flywheel or drive plate to the crankshaft I found two different values. In the engine section under "Crankshaft Oil Seal - Rear" the tightening torque given is 101 ft. lbs. In the "Automatic Transmission 47RE- Torque Specifications" chart the number given is 55 ft. lbs. One of these is a mistake; which one is right?
