- Replies 20
- Views 17.8k
It was a good one, but his time will come. I am patient. the part number on my dip stick is 39737748, dip stick with oring. Googled that and anything but a dip stick shows up. The part #
One Dipstick number is 3dripley462 92 12 valve= 11 qts. total 01 24 valve= 11 qts. total 02 24 valve= 11 qts. total My 01 has an added extension riveted to the end.
Anyone out there with a 99 that can get the part number off the dipstick for Leaky88? Thank you Dripley uses his for skewing hotdogs over the fire at the jobsite. He also uses it as a hotd
Hi,
Dodge Manual states: 8Qts. to Lower Safe Mark 10 Qts. To Upper Safe Mark.
Using ESN I looked up my Dip Stick number 3935648 and it jibes. It also showed 10Qts of oil.
I change my oil as follows:
I bring Engine to operating TEMP
Pull it into shop with a Level Cement Floor at end of day.
Place pan.
Remove Drain Plug
Let drain all night.
The next day:
I replace drain plug.
Prime and Change Filter
Replenish Oil.
Problem/concern: I am only able to put just shy of 9.5 Qts in total, back into the Engine to bring it to the UPPER Safe Mark.
Ive driven truck several miles, and it’s still at the UPPER Safe Mark.
The oil pressure is good.
Ive heard that some 5.9’s take as much as 12 Qts.
According to TDR, there were some inaccurate Oil Level Gauges (aka Dip Sticks) fielded, but my 3935648 is not it. At least
to my knowledge and research, it’s not.
For me, too much oil is just as bad as not having enough.
If anyone reading this has a 99, or input, I’d appreciate your feedback.
Id also like to know what the part number is on the Dip Stick.
Thanks
Leaky.
