Trouble with my Ram
Please Help!! I have a 2001 Dodge Ram 2500. It has a 5.9 Cummins Turbo Diesel engine. The problem occurs when engine is cold. I thought it was only in winter like now. But it also happens in summer just not half as bad. when engine is first started cold I get white smoke out of exhaust and it stumbles for about a minute in summer. And if left unplugged (engine block heater) in winter it will smoke bad and stumble for like 5minutes!! Then when it warms up enough to drive it wont go above like 20 30 maybe 40mph for like 2miles or more. Seems like until engine reaches a certain temp.?? Anyway then finally everything will kick in and truck will run and drive great!! I was told by a couple people that the problem is the Turbo Wastegate. I think it mite be more than that?? Can someone please give me some real answers before I start tearing things apart and possibly replacing the wrong things???? Thanks Very Much in advance!!!!
  • Replies 82
  • Views 18.1k
  • Timothy, every one of us have gone thru the exact same scenario that you are going thru. We have all had the modify our trucks to keep them going for the long haul by taking care of the 4 items above.
  • Tim, All I can do is commiserate.  You have the exact same symptoms my brother did, with the only exception you got the P0216!  He never got a code.  Talk about being unsure of ourselves.  Once d
You need to check for trouble codes. That in itself will help save money, Gives you somewhere to start from.
If you're not losing coolant it may be vp related. Something to do with timing. I would think if it was injectors it would do it all the time. We'll get through it, just need to get the ball rolling.
Thank you for your response!! Would u say then that the problem has nothing to do with the wastegate in the turbo?? I don't know enough about diesels to figure this out. If it has to do with timing im gonna have to take it into a shop. That could get expensive.
Nope has nothing to do wit it.
Need to test for error codes and fuel pressure. Then check fuel pressure. If fuel pressure is to low it can't advance timing hence the white smoke. There could be a P0216 code that is timing code of the VP44 which is cause from low fuel lubricity and low fuel pressure. Once the pump housing gets hot the the timing piston will move again. Hence driving normally. Most likely a bad VP44 but error codes and fuel pressure test will bring that forward.
This is a seized timing piston.
Thanks for your response!! Would u say the problem has nothing to do with the wastegate in turbo?? I don't know enough about Diesels. There is no check engine light on. Will I be able to get codes checked without check engine lite on??
No has zero to do with the turbo or wastegate.
Most error codes do not produce a check engine light.
Yes use a OBDII code reader and the list will be given of what is wrong. Now when you do list the numbers here and well look up the codes together.
Need to test for error codes and fuel pressure. Then check fuel pressure. If fuel pressure is to low it can't advance timing hence the white smoke. There could be a P0216 code that is timing code ofr the VP44 which is cause from low fuel lubricity and low fuel pressure. Once the pump housing gets hot the the timing piston will move again. Hence driving normally. Most likely a bad VP44 but error codes and fuel pressure test will bring that forward.
Thanks so much!! That sounds like the problem!!! So if that code is the problem I will need a new Fuel Pump?? Correct??
Thanks so much!! I will have to
42 minutes ago, Mopar1973Man said:
Possibly. That why we need the error codes and test fuel pressure. These two test will rule out what is possibly going on.
Thanks!! I will have codes checked and let u know!!
Beautiful truck u have!! obviously u don't live in Buffalo NY!! lol. I really appreciate your help!! I don't have a code reader and autozone only works when check engine lite is on. I will have to wait till tomorrow to get truck unfortunately into a shop. Could u please tell me so I have a better understanding, without a distributer and spark plugs and wires, how does the timing work on a diesel?? Also could u please fill me in on what the wastegate on the turbo does?? If it was stuck open or closed what would be the situations?? Thanks!! Also just so u know, if engine block heater is plugged in the truck will start up and run fine with no smoke. But it will still only go 30 40mph till warmed up fully!!!
A code reader should read the codes with or without a cel being lit. They might think that but be every code reader I have seen will display the codes that are stored. Timing is done with the injection of fuel into the cylinder. That is done thru the injection pump. It is a bit more involved but I would defer to the more knowledgeable for an explanation. The waste gate is on the turbo charger. It regulates the pressure you can build. A stock WG opens around 20 psi. If it is stuck open you can build no boost and the computer will not add fuel so the truck will run like a dog but will get up to speed although slowly. I dont feel thats your issue since it disappears when fully warm. Again others can explain it better than me.
 Is the truck a stick or auto? It may be stuck in limp mode for some reason. The trouble codes will help a lot.
I had the same type problem with my 2002. It did throw a code. I don't remember the code, but it was for the cam position sensor. Eventually, it threw the 0216 code. Dealer installed rebuilt VP44 under warranty. Still had the problem on a cold morning. I replaced the cam position sensor. No more problems.
You could get a cheap bluetooth obdII reader and read the codes through your phone (you can also use it as a live data reader).  They sell them on Amazon for really cheap to not-so cheap.  Here are a few selections.
Cheap and not-so cheap
I have a cheap one and not so cheap one and they both work well for finding codes.  I've never tried using them on vehicles with out a CEL on though but they should be able to find any stored codes.
This might be a cheaper alternative then just taking it to a shop.
Thanks!! I would love to have my own.But I would have to be 100% sure it would read codes without CEL on!!!! Anyway u could find out and let me know????
You can ask that question of he seller on line. I have never heard of one that would not read a stored code, cel or no cel. Of course I have led a sheltered life and cannot offer personal garauntee.
Im just a little concerned because the code readers that Autozone have wont read anything unless your CEL is on. I would be blown away to see just a wire that plugs into my truck and other end into my computer do all the things they say it does. For $30?? Really??
Several folks here are using them including @Mopar1973Man. Going to get one myself one day. Still using my old scan gauge II for now. It reads codes cel or no cel, as long as there are stored codes.
If you have no stored codes that would be why  the AZ code reader is picking nothing up.
The code readers don’t know if the CEL is on or not, they just read stored codes.
There are hard codes, which sets the CEL and soft codes that don’t. They are all readable with an OBDII scanner.
My OBDLink LX will work on any thing. CEL lit or not.
