Coolant temp
So recently I’ve been noticing when i leave in the mornings for work after letting my truck warm up, my coolant temp is never past 165. No matter how long I let it warm up. I Was hauling my horse trailer this morning it was 34° And the coolant temp never reached 190. Maybe touched it once on an uphill but otherwise no. Is this a problem? Stuck thermostat?
  • Replies 43
  • Views 15.5k
  • 98whitelightnin
    98whitelightnin
    Mike, tracking shows that t-stat delivered yesterday. I sent it in a very discrete valentines day padded envelope.
  • ColoradoColt
    ColoradoColt
    Thanks guys, put in a 190°. Sitting at just under 190 now. Seemed to warm up faster this morning as well. I’m happy about that
  • If it's an hour drive and you're not getting to 190° unless loaded then you likely have a stuck thermostat.    I would start by replacing the thermostat... not going to start another thermos
12 hours ago, kzimmer said:
Is there a documented experiment to support this? Just curious. I like learning facts like this, but only if they're substantiated.
I had one of Mikes or Ryan’s high idle boxes about 10 years ago and for some reason the truck ran 160* with it hooked up. I drove around for a month at 160* and getting 13.5. Finally figured out it was the high idle box And when I removed it, Temps went back up to 190* and mpg jumped back up to 16.5
14 hours ago, Mopar1973Man said:
Like myself I running a 190*F thermostat. Typically with winter temperatures I run about 160*F to 170*F in oil temperature.
It blows my mind that your oil temp could be colder than coolant temp. I'm not sure that's possible.
Perhaps the high idle box was fooling coolant temp, and you weren't actually at 160, just displaying 160.
Efficiency... Less heat lost the more power to the ground. All about the Quadzilla timing.
14 hours ago, AH64ID said:
didn't realize you put a oil temp gauge in. Where did you put the sender? You run a lot colder oil than I did in the 05.
 Oil cooler port on the oil filter housing. Extra temp sender comes with the Quad which is labeled Trans Temp but I know it Engine oil temp. I'm running about 20* at 2k RPMs.
There still isn’t a good reason for oil temp to be cooler than coolant thou. It has no way to run cooler.
It does. I can crank up the timing to make it hotter but... MPG drops out badly.. 15 to 17 MPG. Outside temps in the 10 to 20*F up here. Thermostat is closed and holding barely 192 to 195*F. The lower coolant hose is COLD to the touch.
More timing the hotter the oil temp. More retard the cooler the oil tremp. This photo was a older tune my recent tune is right at 20* at 2k RPM. Remember Trans is the engine oil.
How many miles had you driven at that photo?
250 miles daily trips. This is my standard from New Meadows to Ontario, OR runs and back home. Photo is dated 12/31/2019 (Tuesday)
then I would say your temperature sender is reading more of the temperature of the filter head housing and not the oil. After about 30 miles the oil temperature should match coolant and up from there is based on efficiency
Sorry. I don't know what to say. I've check it many times and it correct. Remember 24V are NOT CR engines. Might hold true for your old truck... Umm the oil is flowing through that port. That is true oil temp from the oil cooler. If not my turbo would sure hate life if the oil isn't moving.20200131_053155.jpg
What I said holds true regardless. If the temp sender is reading the temp of the entire unit and not the tip of the sensor it will read low. That looks like what is happening for you.
The oil actually gets hotter on these engines with the piston and head heat and then the coolant brings it back down. The oil is exposed to more heat and has less cooling.
It’s not 24V vs CR, it’s general engine operations. Oil temps operate at or above coolant temps without external oil coolers.
We can change sensor but it not going to change the temp. I can measure the temp with my IR gun and still be the same. I cant make it hotter being the oil temp is still the oil temp.
You just proved my theory. If the IR gun reads the same temp your reading oil filter housing temp and not actual oil temp. That’s why it’s cold.
The filter head will always be colder than actual oil temp.
It should still give you a good relative indication, it’s just not actual oil temperature. It’s probably about 30° low.
Edited by AH64ID
Still doubt that being the sensor is INSIDE the oil. The sensor the probe tip is nearly 3/4 long inside the oil. The oil is MOVING past the sensor and oil filter into the turbo.
Now I could see you point like in transmission application where people put the sensor in the accumulator piston and the fluid is not flowing. This is in a flowing oil galley and the main oil feed to the turbo.
So I still doubt your comments being the fluid is moving into and out of the oil filter.
Something is amiss. Your temps are what is suspect.
11 hours ago, Mopar1973Man said:
Mike, I found the 200 t stat I pulled out of my 2012 in favor of a 190. It was good when I pulled it and I’ll send it up to you if you want it
Edited by 98whitelightnin
Sure.
All this coolant temp issues and my sensor goes on the fritz last Thursday afternoon. By the time i got halfway home Friday it really wacked out. Put a spare in this morning am and its working just fine again.
I typically see the same temps John did with his 05 in my 14. I have seen temps as high as 245 pulling a very long grade with 16k in tow.
I'd be interested to see what my 2nd gen does, but don't have a sensor to install.
  • Popular Post
On 1/31/2020 at 5:23 PM, Mopar1973Man said:
Sure.
Mike, tracking shows that t-stat delivered yesterday. I sent it in a very discrete valentines day padded envelope.:lmao:
