- Replies 20
- Views 60.3k
dripley 6 posts
Mopar1973Man 3 posts
jncornett 3 posts
Bwebb2119 3 posts
Here is picture of the ground in the harness to give you an idea of where is. As far the electrcal aspect I will leave that to the more knowledgeable folks. Though I have heard of a bad oil
I suspected them maybe being the source of some electrical gremlins I was experiencing. That was not the case. Inhad a bad splice on the 5v signal wire that ended up being the culprit. This was a sel
B, Man you need to start a new thread if you need help. You need to explain exactly what you are testing. Most of our sensors are only 5v. They never see 12v. (The PCM or EC
I have read here about the ground above the atarter for the ecm. will running a new ground from the battery to the ecm serve the same purpose or does the ground above the starter serve a greater purpose than just the ecm?
