Gear hunting, Fuel pressure, and a random rare occurence fuel cutoff
- Replies 15
- Views 4.3k
smelonas 5 posts
dave110 3 posts
dripley 1 post
Tractorman 1 post
Before I fitted a FP gauge I had a sort of engine off moment which would happen at very light throttle accelerating, like a very long cough, fitted a FP gauge and while it was no where near as low as
What you call fuel cut off sounds like APPS to me
@smelonas, I didn't see anywhere in your post with information regarding year of your truck. Your signature shows 2007, but you mention VP44 in your post, so I assume your truck is a '98.5-'02 second
New here, but not new to dodges. Some of you will probably know me from CF.
My grandpas truck, 2001 Cummins 47RE and completely stock, spent all day working on it, various things, but I did some diagnostics and thats why I am here.
Ill start with the gear hunting issue first.
I tested AC noise. has about 0.03V, which is 'acceptable' apparently. Okay.
Had no real way to log the truck while driving, I dont have a snap on scanner or similar to watch APPS and other parameters that might effect TCC operation. This diagnosis was kind of a dead end. Mostly I wanted to identify AC noise and go from there, which I did.
Issue seems to become more prevalent as you drive the truck. For the first 15 minutes of operation, it runs fine. No hunting, perfect. Once you settle between 32 and 37mph with light throttle she hunts, same between 47 and 55. randomly kicks in and out of TCC.
Any pointers or help here would be great.
Fuel pressure. LOL
8psi at idle and a very lazy pump that struggled to bring gauge needle up when I bumped the starter. Pressure dropped to 2-3psi at WOT, or less maybe.. Obviously the pump is the OEM in tank pump, which is useless.
Is there a good aftermarket drop in pump for in tank pump conversion that was done? FASS and airdog come to mind. I read about the FASS DDRP for the block mount replacement and was hoping I could get input on that. A conversion back to that would probably suit him just fine as the truck is lucky to see 5k miles a year. But Im not even sure if thats wise or stupid or what, you tell me.
The random occuring fuel cutoff..
This is a tough one because I dont know how to describe it because I have never been in the truck when it happens. Ill explain it the way grandpa did.
Cruising down the road, pedaling(cruise never gets used ever), doing between 70 and 80 and for no reason it just cuts off. Almost like the FSS or whatever the VP44 has, gets turned to the fuel off position. Hold pedal in same position and truck just coasts, give a juice of throttle and she comes back to life and then goes down the road just fine. Only happens randomly and fuel filtration is no real issue because I have a BF7977 in the stock canister.
Ive searched for a couple years about the fuel cutoff issue(been happening since 2016), and I have never found anything similar. No codes in the dash either. Truck runs really strong, italian tune up didnt really make it run better, so the truck is healthy but it just has some random issue with it.
First time posting to M1973M, looking forward to joining this engaging forum. CF was/is getting... yeah.
Edited by smelonas
