- Replies 16
- Views 6.4k
Vinster_Beta 7 posts
jltait 3 posts
Royal Squire 1 post
Threadzy 1 post
Are you equipped with 4.10's or 3.55's?. For that weight, 4.10's would be best. The factory rating is up to 12,000lbs with the 4.10 gears. 4.10 gears with a matched converter/valve body/line pressure
I’d talk to @Dynamic a lot of guys on here including myself are running his transmissions or at least his valve body’s.
I think since you have 4x4, for hauling the type of trailer you are referring too, you'd be fine with a properly set up 47re. Get a 2wd low kit that allows 2wd low operation. Use that for maneuvering
Currently I have a stock 47re trans as far as my knowledge ( Previous owner had it rebuild but no records of the work done). End goal is to take the truck to 300 - 350hp and cap it. I want to build a reliable towing trans out of what I have and eventually look at a GearVendor gear splitter if I ever get around to it. As it stands now though, its a completely stock motor and trans combo that all works like it should but I want to try to get ahead of the ball on doing the preventative maintenance on it. I'd like to know what I will have to get swapped out and recommendations on what to get. I'd rather overkill the trans than it give out on my 1000+ mile road trips with the Deckover trailer behind it. Any opinions are appreciated.
