- Replies 16
- Views 3.8k
LorenS 5 posts
That Guy 4 posts
Blueox01 1 post
Dieselfuture 1 post
Popular Days
Heat with oxy-acetylene torch, red hot, but don't melt the metal. Heat the flange area, that will expand the hole and brake the rust bound from the bolt.
Dang, that rust looks brutal. Is that the 5 bolt elbow? What do the bolts look like? Is it possible to remove them instead?
Cut top of the studs flush with flange then heat the flange and good luck
I'm putting this here because it doesn't apply to any limited Generation of truck.
Am attempting to remove the exhaust flange bolts from my turbo "about" so that I can in stall my new exhaust.
I have been spraying it off and on for weeks, both cool and hot, with AeroKroil. Today I've laid into it both from above and below with my wimpy air hammer in an attempt to jostle the rust. My guess is that from the top was a mistake, as it could swell the bolt like a river. However, the other attempt from below didn't make much difference.
Any further in-truck ideas?
