- Replies 24
- Views 6.6k
Doubletrouble 8 posts
Mopar1973Man 5 posts
Dieselfuture 5 posts
That Guy 2 posts
***Final Update*** I had my buddy hook up to it again with his snap-on scanner. He found that the rear axle setting was on 9.5", the options were 9.5 and Dana. He set that to Dana since the truc
If you know someone with a snap on scanner I believe it will read abs codes
Maybe the module going bad, scanner would be nice to know for sure.
I touched on this a little in another thread a while back. Finally getting to it.
My abs light flashes constantly. The red brake light on the dash is not on, only the flashing abs light.
I have read through the abs article and it refers to the abs/brake light both being on. So that didn't really give me a definite answer to my problem
Abs light flashing, no parking brake light on and the speedo is working fine, cruise control works, brake lights come on when brakes applied as they should and 4wd light comes on and engages as it should. I did replace one front wheel speed sensor yesterday, planning on doing the other side either today or tomorrow but I feel it may not be the issue.
Anyone else ever run into this?
Any advise would be appreciated. The light is just annoying.
