W-T ground mod/150amp breaker question
- Replies 18
- Views 4.6k
Doubletrouble 6 posts
Mopar1973Man 4 posts
hdpwipmonkey 3 posts
Dieselfuture 2 posts
I forgot to report back but so far, after 1 night sitting at work she seemed to fire up just fine. Grid heaters are hooked up again and the new breaker has not tripped once yet. So far so good.
Mine is attached to the passenger side battery tray as well, but on the front side of it. Nice little bracket @Dieselfuture
I have mine in front of the battery box on the driver's side. It's cool out now so heat at first shouldn't be an issue. Maybe after she warms up good. I'll report back after tonight.
I kind of touched on this in another thread but can't remember which one or find it so here we go. Sorry for rehashing this.
I did the basic W-T ground mod and installed a 150amp breaker between the alt. and passenger side battery. The breaker seemed to trip early (it was a cheapo from Amazon $12 made in china) but prior to the mod not once did it ever fry the 140amp OEM fuse which leads me to believe that the breaker is sub-par.
So my question is:
Which 150amp breakers are you all using with no problems? I have no tuner or major mods for that matter, basically stock truck, original alternator with about 148k on it.
Need to get this done since it is getting chilly and I'll need the grids before long and the extra draw there will surely trip that cheap breaker. I've had them disconnected over the summer.
