A Shutter, a stutter, a miss?
- Replies 25
- Views 6.9k
Alexio Auditore 7 posts
LorenS 5 posts
Mopar1973Man 3 posts
dripley 3 posts
Checked the temps after work today, both were only a degree off from eachother. So I'm thinking its fine.. Winter fronts, is that the cover you throw over the grill or radiator? Her
Consider doing an adrenaline by itself instead of the EZ/Injectors combo. It will give you gauges and custom tuning and enough power comparable to 100HP injectors and EZ.
You are describing something very similar that happened to me. It did turn out to be an engine miss under the same driving conditions as you are describing. Mine started just after I installed RV275
So, for a while, I thought maybe I was breaking traction in the high gears, 5th and 6th, when I would pour the coal to it, usually the roads were a little wet, so I couldn't confirm for sure, but I had my doubts. Saturday, my wife and I are driving home, I hit the free way, trucks warmed up to temp, and I accelerate like normal to merge up to speed, but I could definitely tell something felt off.
Under normal driving, I dont notice the truck missing or stuttering at all, like cruising speeds,, but when I lay into it pretty good, it has what I can only describe as a miss, but the truck doesn't sound like it's missing. You just feel it, even my wife said she noticed it. I slowed down and couple times and sped up quick, and would get the same thing to happen. Its hard to do in the lower gears, 5th and 6th I have more rpm range to test it, but what could it be?
No codes
Clutch has 80k or so on it, southbend
Injectors are God knows how old, so there's another possibility.
Fuel pressure does what its done for years, it drops, but not enough to starve to i.p.
Any other ideas? If its injectors, then I'll probably do those along with getting the head surfaced( leaking coolant from passenger side)
