wipers
Had a couple frosty mornings out here the past 2 days and noticed the wipers started real slow. Today I leave in a drizzle and no wipers at all. So I figure the wiper motor is shot. Have open it up and make sure the linkage is not bound up and if not it is new wiper motor time. Anything else I should look at that anyone knows?
  • Replies 22
  • Views 6.8k
  • Dripley and the little Misses relaxing in the tub after a long hard day.  Dripley  likes to call it "making chicken broth".
  • Ya'll better put sun glasses or blinders on. This could get strange quick like.
  • Clean up the linkage and add a little lube/grease to the moving parts.  With the cowling off, now is a good time to install a screen or filter over the fresh air openings for the HVAC system.  I have
Clean up the linkage and add a little lube/grease to the moving parts.  With the cowling off, now is a good time to install a screen or filter over the fresh air openings for the HVAC system.  I have my cowling off now and before I put it back on I'm thinking about installing window screening over the openings with  some type of glue to hold it in place.  I've had good luck with Amazing Goop Automotive adhesive.
I Installed these cabin filters from Geno's after I replaced my heater core about 75,000 miles ago.  I wished I would have done it when the truck was new.
- John
- John
Yes, I need filters too...... on my 01 the evaporator was almost half clogged with debri and the blower cage/ fan was full of leaves at 190,000.
Anyone know if there is a fix for wipers that sometimes stop in the wrong place. They always correct themselves eventually, but wondering if there is an adjustment somewhere. T.I.A.
It's the park switch in the motor.  There is no adjustments.
I was also thinking of some kind of screen on the underside of the cowl rather than the filters from Geno's. I like their setup but I guess I'm being cheap. I also need to replace a couple of the funny retaining screws that hold the cowl down and the rubber strip that runs across it. That is missing.
I just pulled those parts of a "98 truck at a Pick Your Part yard this week.
I pulled the motor today. Cleaned the connectors and was able to get work on one wiper. Just doesn't have the umph left to run both. Plus it wont park anymore, on off only. Nobody has a motor instock so i got to order one. No rain in the forecast this week so maybe it will get before the rain returns.
I put window screen on mine with hot glue gun, seems to work.20180812_113729.jpg.03366ddf2031fbf66b016bf5da1f46d6.jpg
There are some smaller holes on the side that I also put some in, can't see it in the picture
I have my cowl off now due to my truck getting body work and new paint.  I'll try some type of filter/screening before being put back together.
11 hours ago, dripley said:
Ordered one today. Should be here Thursday.
I've seen a lot of this lately. Check the local NAPA for simple thing like seal or gasket maybe a thermostat no stock. But now head to RockAuto sure enough they have the part in stock yet. Like my last trip to Lewiston I was trying to get injector seals for Jacob truck and nothing in stock. We tried O'Rilley's and no problem they had it. Amazing how much stock is not there.
No one here stocked the pump. Had to order. Almost bought from AA but ordered some extra stuff to. AA had 20% off and free shipping but RA wa still 15% cheaper. Funny thing is the Car Quest part showed the same pump with the Cardone sticker on it. Alll in all I saved 20 % or more from RA. Though with AA if the part fails they will just give another. Got weigh out where you get off better I guess. Who knows the best decision on that doo doo.
On top of that I got my tracking info on the parts. RA said usps on the shipping method I chose and the tracking says fed ex ground to be delivere by Wednesday this week. Not bad for cheap shipping and ordering on Sunday evening.
We won't be able to breath till you post a picture of the work when done. And Dripley won't be able to work on the Chick-Fil-A's. much.
My parts got here Wednesday, not bad for ordering on Sunday night and economy shipping. Pretty happy that.  But got up for work Wednesday morning at 5:30 and while standing in front of the bath tub buck naked,  there is no hot water. Get your mind around that picture. Water heaters craps the bed. So while working at the CFA I call my son and ask him what he is doing this afternoon. He tells me he is knocking early to relax. Bad day for me to call but he hears my situation and goes and picks up the heater and gets to the house and helps install it. Damn good man he is.
The wife got a plumber to come over and check it out. He tells me over the phone that it will cost 1200 bucks to replace the heater. $540 for the heater cause its a low boy and the rest labor since its in a crawl space. I aint going for that. So 400 bucks for the heater, 30 bucks for the 5th of Crown Royal and 3 hours of fun i stalling it and we have hot water again.
My god I think I have hijacked my own thread.:sofa:
Anyway i was thinking of screening tha back side of the cowl. Kind of a different take on @Dieselfuture screening the openings under the cowl.
:thud: @IBMobile probably has a picture of that :think:
  • Popular Post
I had to go to work today and after answering questions, reading the news, eating my breakfast and it warmed up nicely I went after the wipers. Before ordering parts I did a little testing and got to thinking it just might be the multifunction switch. I was convinced enough that I ordered both. Sho nuff it was the switch. But I swapped both so maybe I want have to go in there for that again. So I now have working wipers and a new washer pump, the old one was a bit tired. I can now wash the roof of my truck again while sitting still.
But in my wisdom I forgot the screen for under the cowl. So I am still screen less.
Thanks to all and special thanks to @IBMobilefor the graphics. Whew!!!
My wipers have been shutting off in weird places since I bought it, top of windshield, halfway down, etc. That's not normal? Lol!
  Anyhow, should I assume it's that multi switch? (Blinker switch)
   Those silly Dodge brothers didn't see a need to have a cabin filter !!!
  Thanks!
