Trac-Loc Clutch replacement
- Replies 31
- Views 7.8k
Wouldn't hurt to change oil and add friction modifier first and while you draining it check for bits. As for rebuild you will need to either slightly press the casing top to bottom or make a too
I think I'm going to just service it this time, all the gears, R&P/spiders look good. Trying to clean some of the sludge that has built up over the miles out, then have some Lucas SYN 75W-140 and
I agree. When did you change it last and with what? Normally, when a Trac-Loc wears out the clutch's, you just have an open diff, no unusual operation. If you are getting clutch chatter when you turn,
I'm staring to feel a vibration from the differential when starting from a dead stop, especially when turning a corner, thinking my Trac-Loc is done, anyone ever R&R that carrier? I figure since there's no problem in the ring gear/pinion gear wear pattern, I should be able the replace those clutches with just pulling the axles (3500) non-weight bearing on the axles, just make sure I put back any shims that might be under the carrier bolts. Don't think I would have to even mess with pinion. Any thoughts? If I remember right when both wheels are off the ground,when a wheel is rotated both wheels should spin in same direction,right?
Edited by Blueox01
