Turbo Compressor Dirt
Is this a normal amount of dirt on the compressor blades? Turbo only installed a couple thousand miles. I run a stock style WIX air filter and it's fairly new and clean.
  • Replies 42
  • Views 7.9k
  • I'm officially in the Big Obnoxious Air Filter club!
  • Doubletrouble
    Doubletrouble
    Think of it as a warning whistle for other drivers that your spooling up and ready to unleash the beast.   Just like when a guy at work told me my truck was leaking (water separator valve on the f
  • Doubletrouble
    Doubletrouble
    There's a joke there but I'll let it go. 🤣  I wasn't sure if they were reliable just because I've never seen mine move. I have seen them work on big trucks (18 wheelers and such) but not my dodge
I just reached in with my finger and wiped it off each blade, but the turbo has only been installed a couple thousand miles.
  • Popular Post
"Livin' that BOAF life."
The highest pitches coming from the turbo are extra annoying now. I may have to cut up a (metal due to heat?) 5 gallon bucket or something to see if I can attenuate that ruckus.
Wait till you upgrade turbos and there is no silencer ring option, then BHAF added then it just there you can't reduce the noise very much.
I hope I'm done with that for a long while, now that my HE351W is installed.
 Think of it as a warning whistle for other drivers that your spooling up and ready to unleash the beast. :burnout:
 Just like when a guy at work told me my truck was leaking (water separator valve on the filter housing) I told him "it isn't leaking, it's sweating torque"
I have never minded the turbo noise. Its the other noise I hear from BHAF that bugs me the most. But I have gotten used to it to a degree. The stock air box seemed to muffle that noise.
I think I know what he means there other background noises you'll hear like a thumping noise, the turbine whistle, and other things depending on the setup.
The BAHF seems to amplify noises thru the intake system that I do not hear with the stock air especially the thumping noise  The turbo whistling has never bothered me
Installed my new filter today, fits good. It didn't help my turbo whine tho, same as before. This new turbo is quiet:( The exhaust brake rumble might be just a tad louder.
Looks like my oem was working good, compressor wheel is still shinny. It was due tho, 1 year and 24k miles of a lot of dirt roads.
0504210908.jpg.0855b338b0e62d83fb97290faf8bc382.jpg0504211140.jpg.8b6d1e480b40721f9314bb18c77d3661.jpg0504211140a.jpg.44bcbce5bcf704f3340de50114d649e0.jpg
I hooked my Filter Minder to my Mity-Vac one time and got it to move.
Maybe with a heavy load, high RPM, and obviously dirty filter it would move.
Here is an article @Tractorman did on making the BHAF a little bit quieter.
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/air-exhaust_56/bhaf-muffler-uhh-r612/
6 hours ago, Doubletrouble said:
  Did your filter minder show that it was dirty? I ask because I wonder if they really work. Mine hasn't moved a bit since I bought the truck.
They do work but it takes a good amount of dust to trip one, on road I doubt one filter through the entire life of the truck would trip it, dusty conditions yes but filter more than likely changed before it trips anyway.
The newer electrical sensors work but probably too well and some can be a right pain
Put the filter minder to your lips and lightly suck on the filter minder nipple it takes very little vacuum. It actually measured in inches of water column. Just like a drink straw how much vacuum to pull few inches of water up a straw.
 I wasn't sure if they were reliable just because I've never seen mine move. I have seen them work on big trucks (18 wheelers and such) but not my dodge. Not yet at least
Welp, that lasted quick. Down on boost and up on EGT's. What the heck? Bad filter? So, it went back in the box on the shelf for the dually and the '01 gets a new filter and old air box. I made sure the elbow was not restricted in any way, yet? Some times ya just gotta use oem:)
