- Replies 45
- Views 10.1k
Mopar1973Man 9 posts
CAMG3X 7 posts
dripley 6 posts
Dieselfuture 6 posts
I put mine back like stock. Machined the head, stock gasket, and reused the stock bolts. They were well within Cummins spec. I do have Comp on it and it held the power just fine. If I ever went to a Q
Normal here at home I can tow about anything and stay around 180*F towing but about 140 to 150*F empty truck. This includes climbing 7% grades for 7 miles. Now as for Arizona I make a simple heat shie
Sounds like it's original hg then, and at some point you put in arp studs in one at the time I assume. Could be just the time for it being that old. Mine never leaked coolant, it was pushing oil from
Well, been looking over the truck the last week. Originally had, what I thought to be, a bad water pump. Looked to be leaking out weep hole due to coolant seeping along the timing cover below it. Replaced the pump and all was well for a couple days. After a 4hr trip I found a small coolant puddle. Started tracing it and found the source at front-middle of the head. Leaks down behind the fan housing and follows the timing cover under the water pump
Warmed up the truck and when I squeeze the upper radiator hose small bubbles emerge from the head in the area pictured.
Will start tackling the head in the next couple weeks. Surprised it blew with arp studs in place at 135lbs...
Is this a common area for it to go and is there a water jacket behind there? Could the new pump have had anything to do with it?
My first time ever having to do a head so I'm sure I'll have plenty questions along the way.
