Front end popping noise
- Replies 32
- Views 10.5k
dripley 6 posts
puglyfe 6 posts
Mopar1973Man 5 posts
LorenS 3 posts
To find your sloppyness, you have to get someone to wiggle the steering wheel for you. You will begin checking in this order: 1) Steering shaft to steering box. put your hand on the shaf
I was able to get it checked this morning. The steering box needed to be adjusted. It is now back to the normal feel and response to input. The track bar and steering shaft appear good at this time.
One of the worst jobs on my truck so far has been changing out the control arms, due to rust. All my dad's cool tools from working on yellow iron couldn't blast out a couple of those bolts, so bought
This just started this morning, a popping sound when making a tight right turn at low speed. In a parking lot for example. Had not done it turning left at all. Wife said she felt it in the floorboard when it popped. This is while in 2WD. Have not tried in 4WD yet.
No obvious cause when I looked under the truck. Truck has 187,000 mile on all the stock hardware except shocks which I replaced last weekend.
Suggestions on what to check for?
