I'm Back, Finally! And I have some good questions/ topics
Hey all, been quite a while since I been on, had alot going on. Stepped out of the Military-may go back in?, moved into a new house, jobs, kids etc you know. Had the truck LITERALLY completely torn apart: re-sealed engine minus head, completely rebuilt the NV5600 and transfercase, new clutch - which is making some very strange noises, sound deadened the whole cab, re-sealed the hvac box top to bottom, new heater core, evaporator, drier, headliner, wheels and tires; I mean the works! Ill have to maybe make a post with all the pictures? I don't know how to add that many pics though. If youd like to see it all give me a shout and how to do it and ill throw it up.
Any how, down to the good stuff. I have multiple topics id like some discussion over/ questions answered. They are all non-powertrain related so I feel it appropriate to group them here, if not Ill gladly make separate topics to keep everything organized.
I guess Ill start with the dash. I have been looking, reading and researching the DASH. Came across alot of topics here including @Dieselfuture post Time for a new Dash. I think I have decided on going with LMC dash cause I really don't wanna mess with painting it and trying to get it to match :pray: I have spent alot of time already with my dash out fiber glassing  the top and bottom in hopes of making a custom dash top (see pic) and I don't wanna mess with it no more, I'd be cheaper off to just buy one. In that same realm Ill be purchasing a new dash bezel from Geno's  for 87$ - no brainer.
Next on the list is sway bar stuff. I have a 34mm front and a 24mm rear sway bar. They have been off for years, I don't do that much offroading in this rig and I hate the body roll- sometimes. So I'm gonna re-build them and put them back on. With that I am thinking of using Geno's to get the Energy Suspension bushings - still waiting to see if they can get the rear ones, and also front and rear end links from them. Need to see if I can even find the bushing retainers to bolt on from when I took them off...... Thoughts on this?
Lights! These things suck! I have read the article on here for the sport light conversion with projectors. More than likely Ill go that route - with the detailed instructions. Where is the best place to get those lights at now a days? Any further improvements or light availability come about? I found Anzo Lights from CPP Diesel that look pretty decent, but I'm after quality and some bright a$$ lights so I can see. So I need opinions.
Second light topic is cab lights. I have (smoked colored) my original ones long time ago cause that was hip:think:, and had led's in them, now I'd like to get something updated and nicer looking, even if its new OEM style ones. Been looking at Recon cab lights... Any thoughts or users of those?
Mirrors! going to replace my stiff broken tow-mirrors with something like  Spyder X-tune Mirrors from CPP Diesel that are powered and heated. Any other preference?
Lastly I will probably need to replace my steering gear box. I have everything replaced with DOR parts, great stuff, minus the track bar. I have slop left to right while driving straight down the hwy, it gets really bad wander (hard to keep center) when I try to (quickly) change lanes or go over some (whoops) down a back road. Like I have to correct my correction :lol:. So after alot of reading I have found that Blue Top is the more gooder:lmao: way to go. However they are back-ordered now but who isn't... Thoughts on RED vs BLUE?
Ill probably make a separate topic on this one but my wiper delay and power locks dont work anymore.:cry: Through my research it leads to the CTM, to which I have no experience with...
I think that is all I got for now lol. Quite a bit to swallow in one bite but there it is... Again I have done so much to this puppy and have lots of pics I could show it off or if anyone is curious on something or just nosy I'd be happy to share if I knew how to do it.
I greatly appreciate any feed back, comments, suggestions you would have for me. Thank you for reading through all that!
  • Replies 115
  • Views 18k
  • Well I guess a little update here:    To piggy back on the CPP ordeal, I received my package (2 of 3) item Friday at 1530 right as I was leaving the shop. After all that with no means of rea
  • Silverwolf2691
    Silverwolf2691
    Most of the time when I hear about lope-ing (loping?) it sounds like the video or slightly more pronounced, more akin to a cammed small block or big block. Usually when you dig through the comments on
  • -sigh- all right, I'll add it to the list, I guess...   It's a Cummins... how would you ever know if there are rattles in the dash?
2 hours ago, Stanley said:
Grid heaters kinda worry me the more I think about it lol being just not there and unplugged
NO big deal.   A few people here run the grid heaters disconnected in the summer or have done this modification.
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/grid-heater-bypass-simplified-r662/
IAT and grid heater are not the cause. Both Thor and Beast are currently disconnected.
As for white smoke its timing related or injector related. Like I mention somewhere else that a cracked nozzle you can't see but will make it run rough and white smoke I just had this last week with another local friend that wanted +140 HP injectors in his 1994 Dodge Cummins 12V. After his trip to California and it ran good. Now he goes to McCall and blows the head gasket. After doing the head gasket and getting it running the white smoke was bad and running with a mild miss at speed. After pulling all 6 injectors one nozzle was cracked and the other injector had a sticky pintle. After DAP serviced it out we install and problem gone.
MAP sensor will not cause white smoke. It will only limit your fueling ability.
These trucks will run fine without...
  • MAP sensor
  • IAT sensor
  • ECT sensor
The only impact it will have is low power. Limp mode.
If a sensor is reporting wrong information say its 50*F outside the ECT and IAT should be close to the outside air temp at first key on. Typically mine matches between IAT and ECT values. Remember that if a sensor goes out of range hi or lo then code is thrown.
This is required so that current is detected and a code isn't set, right?
If so, could a guy put a dual position switch in the factory trigger wire, and when grid heaters are switched "off", the trigger wire current would just pass through a resistor to ground?
This makes sense to me if the MAP sensor showed zero boost, but the ECM thinks he has 22 pounds of boost. Won't it then inject a massive amount of fuel?
Simplest way is to unhook the main power feed to the grid heater on the driver side battery. Takes just a minute or two. It will not throw a code. Any mod that messes with the smaller wires typically will set a P0380 or P0382 code. I know @IBMobilemanaged to do this mod and make it work but, keep it simple stupid (KISS) works out even better. 1/2 wrench remove a nut slip the ring terminal off and tighten the nut back up. Typically I unhook in the spring in April and leave it disconnected till October then hook it back up. It 45*F this morning and both trucks would fire up right now without grid heaters.
I did this in my first attempt to do a by pass and it is installed on my truck; it work fine but not KISS.  Here is the article.
 https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/grid-heater-bypass-r618/
I'm pretty sure I have a miss/shudder when throttling up from 2k and with a lug on it sometimes. Kinda hard to explain what u feel while driving buy I guess the only explanation would be a shudder or miss...?
So should I run map sensor I have now knowing it's off and just pull injectors now or do both?
Either way I think it's safe to say I'm pulling them out, just gotta find a ride to borrow for work real quick. I guess if their too bad to rebuild, I'm calling up @dieselautopower again for parts 😉
I got and extra set of cores too. Maybe a bundle deal 😘
As injector pop pressure start to drop off below 290 bar typically it picks up a random studder or miss. Mostly will be seen after warm up usually. Even a bad nozzle that is cracked will do it all the time.
I see you have 6x.018 now.  Are you looking for bigger injectors or something smaller to match the 64mm turbo you have now?  We can rebuild your injectors as well.
I had that and between changing injectors to 7x10 vco pop 320 and fixing ac noise problems went away.
Funny you should ask that question today @dieselautopower
I went and got my injectors popped etc, I kinda knew what was gonna happen when I pulled them out anyway, 3 and 6 was the best ones and they barely made any pattern more of a drizzle, the others just gummy! So holy cow! That's prolly the big reason it's running like crap!
Got back to work the called @dieselautopower and talked to I believe (Mitchell)? Sorry can't remember lol. Very helpful kinda explained what my options were etc. He described my 6x18 as 400hp + I didn't know they were that big! So after talking a min we settled on 6x.013 I think he said around 250-300hp flow. It will work with my DF pump and in the future pair up nicely with twins. Hopefully they shipped out today if not they will tomorrow, they had to whip me up a set😉
Awesome guys at @dieselautopower! Really appreciate the help and guidance, Thank you.
The cross over tube are a heck of alot bigger than stock! You could suck a milkshake through it🤣
I have a brand new set of oem cross over tunes if anyone's looking, and a set of oem injectors/cores maybe. Make a heck of a deal!
I am gonna go ahead and knock out that mod too!
I seen @Mopar1973Man write up on the mod but I can't find the original @W-T article. Maybe I'm overlooking it or it didn't pop out at me. I was wanting to reference both when doing it.
  • 3 weeks later...
Hey gang, injectors have been in the truck for a bit and man what difference. Night and day! Way different drivabilty and mannerisms and doesn't smoke that much. Super happy! I found that my lope is still there but I guess I'll blame it on the tubes, lines etc and leave it at that. Nothing else I can do...
Maybe tuner? Adjusting fuel going to idle to compensate for bigger lines etc?
I will need a tuner for sure. Definitely can tell trucks itchin for more fuel and it can handle it.
Truck even sounds different with new injectors... it's not a low grunt or grumble anymore. Idk hard to explain but it sounds different lol.
Load off the shoulders, now just small(er) things to tackle and mess with.
On 8/31/2021 at 4:55 AM, Silverwolf2691 said:
Weird name, doesnt pop out immediately when searching for "W-T ground mod"
@Silverwolf2691yeah...I was trying to be comprehensive with a "name" for the Original article to cover a wide search regarding the covered subject matter. I have NO idea how it was slanged into W-T ground mod....I didn't do it. Truly "ground reference" should have sufficed.
I disagree! Much like Heimlich's maneuver, so, too, does your modification and contribution to society demand proper-noun, capitalized name recognition.
