- Replies 43
- Views 7.2k
Mopar1973Man 9 posts
DownHomeDiesel 9 posts
AH64ID 7 posts
Silverwolf2691 6 posts
Ok my 2 cents Bosch 275 hp rv and a edge turned up is old school but it works. Stock turbo and and a bd e brake. 100 hp will wake it up just fine. Why reinvent the wheel. But if you had a auto instead
G is for gated the GXE and SXE are updated with many features for more airflow and longevity. if your goal for peak power is 450HP then the 12CM would be of benefit, there would be a
Smaller turbo is your friend for towing. 500hp is easily achievable with 150s, a quadzilla, and a 62/65/12 or 62/68/12. Larger turbine wheel will help on the high rpm end. If you are stuck on compound
I think I'm finally ready to ask these questions. I have decided to upgrade my 24v with a quadzilla adrenaline, injectors, compound turbo, and an exhaust brake. I am not interested in rolling coal. I do not race but I do tow. I like reliability and longevity. My NV4500 has a 450hp clutch. And I'm installing a new lift pump and lines.
I'd like suggestions on compound setup and which injectors to match them with. I initially planned to build my own setup but now I'm leaning to buying a kit. I feel like I want to be in that 350-425hp area. If possible I'd like to keep air filter in place (corner of passenger cowl) but it isnt a deal breaker.
Thanks for any input.
