- Replies 32
- Views 6.7k
								Mopar1973Man 6 posts
								ISX 6 posts
								bronzebeard9 4 posts
								Rogan 3 posts
i just went out and fired up "Blue" (my truck) its about 8deg out and its gunna take a while to get her warmed up, so i was thinking, rather than a mechanical high idle mod, what if i put the engine under load? would there be a problem with simply applying the parking brake and dropping it into drive? (aside from having the vehicle running and in gear without anyone in it...... but i would be in it so that is a non issue, the only way i would consider leaving it unattended would be if there was a safer system or if i could devise a safer system other than the parking brake) seems to me it would warm up a lot quicker if it were under load and i think that would also solve the problem of exhaust valve "gunk" build up that occurs when a diesel is left to idle for extended periods. anyone have any thoughts on the idea?
i decided i needed to edit the original post as i was not conveying my entire thought process, what i added is in bold and italicized .
