Alternator (Bearings are failing)
- Replies 15
- Views 4.8k
Mopar1973Man 4 posts
Junkman 2 posts
jshmohr 2 posts
fire176969 2 posts
Ok gang... I got my next task at hand.
Got up this morning and had to run to McCall to do a bit of grocery shopping and when I fired up the engine I had a strange growl/howl that was unsual. Went shopping and returned home and figured I would check it out. Pull the belt and check the tensioner bearing smooth and no wooble, water pump feels good, and the fan bear is good. But get to the alternator rough and howls when spun. Assuming I found my source of noise.
I know Prowelder did a write up of a alternator rebuild on CF.com
http://www.cumminsforum.com/forum/98-5-02-powertrain/257771-bosch-alternator-rebuild.html
Also I know he got parts from Fixinrams.com
http://www.fixinrams.com/
What the best price for replacement alternators?
