Air filters Pre-Filters
I have read and heard of people using pre-filters on their air cleaners. But have yet to fine anything in forums. I travel cross country each year and have been in very dirty environments. Like my trip last year. I drove through Texas, New Mexico and a part of Arizona ... when somewhere in Texas was on fire and the farmers were plowing for their planting. The debris in my air cleaner was black and mostly blocked it. I have a reusable filter and all I did was take the time to clean it and on the road again. If it was paper, I would be changing it out each time it was plugged, until I was out of the area. It was bad on I40 then.Has anyone used a pre-filter before ?If so, what was your conclusion of it's effectiveness ?
  • Replies 40
  • Views 10.3k
I definitely agree with the filter minder. Found one in a junk yard, made a wall bracket and fitted it in my wife little 03 gasser when I bought it new. Works great. I see they finally have satellite minders for sale. Should be standard in ALL vehicles sold in the USA.But as for the the savings on paper verses oilier ? Because I watch what the reminder tells me, I've only had to do her filter twice since 03 and I'm not even through with the first service kit. Maybe three to four more services with the kit before I need to get a new one. Savings ? Not sure, if any at all. I don't know how many paper I would have gone through. I have pulled the downside of her air cleaner to see if there was oil/debris in the tube or on the MAP sensor and found none. But like I said, I make sure of no over oiling. It still seems a personal preference or belief in my eyes on style of filter.I finally received my Outerwear pre-filter and fitted it on my filter, now the waiting game to see if I'll be happy or not. But loved the info by Outerwear, where they say it's good for 15k and is recommended to replace then. I guess they want a constant yearly customer.
I run a paper BHAF with out the Outerwares. I put the filter on not long after I got the truck on 05/01/01. Last summer I finally replaced my filter and I also had the filter minder mounted on the filter. I have not been able to pull the filter minder down even a little, but after 100k miles I changed it. The new filter was $50 so it only cost me $5 per year to run it bare. What I am trying to say in I don't believe they are needed. Oh, I also run a fair amount of dirt roads and tow a bit too.
Thanks for the info. I've never had a paper filter in for more than max 3 years. Not that it really needed changing, just me not knowing if they would crumble or not. Was there any degrading of the material ?
I have a friend with a 2011 6.7. He put a AFE intake on it and was throwing codes for excessive flow at the MAF. AFE sent him an pre-filter sock and the codes went away, he also said he lost a lot of low end performance.. Not sure I subscribe to the outerwear as a constant thing, I'd rather spec a proper filter and change the filter a little more often, but have the outerwear (pantyhose) in the truck if you got into a smoke/etc situation. I will probably go throw one in the truck's tool box just for that reason.
I've had this pre-filter on for a 1/2 tank so far and would like to ask those who have them if they noticed a slight drop in mpg with it on.I go by hand calculation only, but since new, I noticed the lie-o-meter will be off by 2 mpg +, yet constant. Since this has been on, it's lower by 2 mpg than normal. Nothing has changed except the weather by being a few degrees lower, but nothing like your up north. Road conditions the same, fuel the same, driving like an egg is under my foot the same and loads then same. No changes except the outerwear pre-filter.Anyone else noticed this ?
My last tank was my first tank with the outerwear and it was my best tank in over a year. I also adjusted the valves mid tank too.
My first BHAF lasted 7 years and 130K miles before I gave up because the media inside the filter was starting to dis-color slighlty and I didn't want to push my luck too far. Still no restriction shown by the filter minder...
I've had this pre-filter on for a 1/2 tank so far and would like to ask those who have them if they noticed a slight drop in mpg with it on. I go by hand calculation only, but since new, I noticed the lie-o-meter will be off by 2 mpg +, yet constant. Since this has been on, it's lower by 2 mpg than normal. Nothing has changed except the weather by being a few degrees lower, but nothing like your up north. Road conditions the same, fuel the same, driving like an egg is under my foot the same and loads then same. No changes except the outerwear pre-filter. Anyone else noticed this ?
Based on what happened to my buddy with his '11 and outer wear I wouldn't be surprised if it's the culprit, or part of. Does the banks replace the torque tube?
i have run my outer wear and bhaf for just over a year and if ther was a mpg change it was not noticable.
AH64ID - The Banks system has been on for I believe 4 years and the unit supplied everything from the turbo to the grille. And M1973M, I never owned a paper filter except the original on any vehicle I've own. And I will say they are WAY smaller compared to the one BHAF that I've seen. I will say I was hesitant on over 3 years on a paper filter even though the filter minder indicated it wasn't plugged. I guess I'm old fashion in my beliefs. I 'felt' safer and the prices weren't bad. The same with this Banks. I can go by the filter minder, or as I do to make me 'feel' at ease and clean it once per year, minimum. Earlier this year was the 1st time I cleaned it out twice in a 12 month period with all the cr*p I picked up driving through all the high winds of dirt and fire debris through Texas, New Mexico and Arizona portion of my last trip.
Here is my 6637 on the right, used as you can tell, and my 2790 on the left. new
Posted Image
Here is a visual of the diameter.
Posted Image
If that 2790 on the left wears out in under 40,000 miles ide be surprised, because the 6637 lasted about 52,000, and it saw service is really bad areas.
AND if you look inside you can see the filter is still clean as a bell.
That new filter is rated for about 50% more CFM too!
The Fram boxed BHAF I bought off ebay was made for Fram by Donaldson and so maked inside the package...
From seeing the inside it appears to be doing its job.
Recently did research on this BHAF and from the internet suppliers, they say up to an '02. Might fit in something later, but with modified parts and fittings. Need to get measurements to see what's up.How many who owns a 2003 and later has one under their hood ? Seems everyones sig I seen here that has one in is an '02 or earlier.
I never had one on my 03 but have seen several threads over on the CF that have done it. I think you have to get some pvc pipe with a 45 degree bend or so to make it work.
Could you hunt up a few link on that and post it??? :shrug:
I'm not sure if the intake tube on these newer trucks are smaller or not. Maybe bigger? You could also reverse if it is different. But what about a rubber bellhousing from the hardware store?
Looks like PVC and Fernco couplings. Standard hardwhare stuff.
