- Replies 51
- Views 18.5k
I6FREAK 17 posts
Mopar1973Man 13 posts
dripley 6 posts
JAG1 5 posts
I have not upgraded recently, shouldn't it always have the lift pump run around 25 seconds if the starter is bumped....Not sure if there is a PCM issue or what? My battery voltage is 12.6 volts, 13.98
I have a 99 5.9 24 valve 2wd, auto..... My fuel pump is not powering on anymore, when the key is placed into the on position. With the fuel heater on my "On Position voltage is around 11.8 to 12.0 volts.....it has been around 45 in the mornings here, and my grid heater/s are cycling normally. My issue is that my fuel pump only starts running when I start the engine. There is no lag time, it starts normally and the grid heaters stop cycling after about 30 seconds plus or minus. I do not have any fuel leaks and am running 17 psi at idle as soon as both fuel pressure gauges (electric and mechanical) top out about 1 second give or take after it starts...... this is not what it did for the last 4 years.....Also when it is bumped it turns on for a split second and shuts of right away, it doesn't even get to 10 psi and pump shuts off. there is no voltage going to the pump... it is not the pump's issue... can anyone shed some light.... everything else is functioning normally and no light has turned on.Thanks,Will
