Lift pump is not powering up in the on position
I have a 99 5.9 24 valve 2wd, auto..... My fuel pump is not powering on anymore, when the key is placed into the on position. With the fuel heater on my "On Position voltage is around 11.8 to 12.0 volts.....it has been around 45 in the mornings here, and my grid heater/s are cycling normally. My issue is that my fuel pump only starts running when I start the engine. There is no lag time, it starts normally and the grid heaters stop cycling after about 30 seconds plus or minus. I do not have any fuel leaks and am running 17 psi at idle as soon as both fuel pressure gauges (electric and mechanical) top out about 1 second give or take after it starts...... this is not what it did for the last 4 years.....Also when it is bumped it turns on for a split second and shuts of right away, it doesn't even get to 10 psi and pump shuts off. there is no voltage going to the pump... it is not the pump's issue... can anyone shed some light.... everything else is functioning normally and no light has turned on.Thanks,Will
  • Replies 51
  • Views 24.2k
  • I have not upgraded recently, shouldn't it always have the lift pump run around 25 seconds if the starter is bumped....Not sure if there is a PCM issue or what? My battery voltage is 12.6 volts, 13.98
Yes I understand and have experienced the 2-3 second pressurizing up when first turning to the on position and 25 seconds when bumping for around 5 years now..... what I am experiencing now is no pressure at any time turning the key to the on position and only .5 second pressure increase from 0 psi when bumped. It maybe gets to 10 psi during this brief time. I'm pretty sure that all i have to do is find the item that is drawing too much current...creating the voltage spike that tells the ECM to lower the voltage.... what do you think?
Well if you got a AD or FASS then there is no load on the ECM just that the ECM triggers the realy for the pump so there is virtually no serious amp load there. I so I would check the stock ECM leads for voltage...
I actually am using the rapter which plugs into the stock wiring harness....I would really like to hook a 12 volt switch up to give it a full 12 volts to be sure... Do you see an issue with this? Also.... Did u remove your grid heaters? Did it set a code, and how cold will the truck start at.... I noticed that I get voltage fluctuation between 13.2 and 13.75 within the first minute... Which I thought were the grids, but it was 74 degrees...what do u think is the deal?
You can but leave the switch off during cranking. If the switch is on during cranking the pressure will be too high and the truck will fail to start. Hence why the cranking voltage is modulated to 50% duty cycle to reduce lift pump ressure.
My grid heater as in place but disabled electronically. No code... As for the grid heater they maybe active because the manifold air is colder yet. Remember the cast iron block hold cold for a very long time. As for cold start with my grid heater disabled I can start down to 30-32*F easy without missing a beat... But the coldest I can start from is +25*F and then it starts to miss and shake getting going. At that point I trigger the grid heater with my high idle switch before I turn the key on...
You can but leave the switch off during cranking. If the switch is on during cranking the pressure will be too high and the truck will fail to start. Hence why the cranking voltage is modulated to 50% duty cycle to reduce lift pump ressure. My grid heater as in place but disabled electronically. No code... As for the grid heater they maybe active because the manifold air is colder yet. Remember the cast iron block hold cold for a very long time. As for cold start with my grid heater disabled I can start down to 30-32*F easy without missing a beat... But the coldest I can start from is +25*F and then it starts to miss and shake getting going. At that point I trigger the grid heater with my high idle switch before I turn the key on...
Dumb question, but..the air dog powers either from battery or alternator per the instructions....so is there an issue with the Rapter pump getting 14 volts? How would you wire it?
I have mine wired to the alternator. Have not had any problems with it this way. That was the recommendation from the instructions when I installed it! :2cents: p.s. IMHO There is NEVER a dumb question! Good luck!
No problem...
I put a twist on this and hooked up right on the studs there in the PDC for the battery lead. This way I did have wires going all the way to the alternator like Gassenomore and not hooked directly to the battery like you I6Freak but the say clean on corrosion free like Gassernomore.
Just wanted to say thanks to you guys who helped me out here....If any of you find out what would causes the ECM to not power the pump during the first second when you turn the key into the "On Position" please let me know.....at this point all I care about is that I have 12 volts at the lift pump, and I do.... thank you very much and Happy late Thanksgiving!!!Will
All I can say is a internal ECM problem because once the ECM is replaced the problem goes away...
I don't know if this has anything to do with it, but in addition to the symptoms I've talked about the wait to start light is on longer than it ever has, about 15 seconds, and it the time it stays on doesn't change based on temperature... It has been up to 85 and as low as 26 in the mountains and it is on for the approximate 15 seconds....not sure if this was vital to what anyone was thinking about... In my opinnion it just adds more validation to Mike's ECM conclusion.
Sounds about right... :rolleyes:
Strange symptoms with my truck too. This morning the ambient was 34 deg F when I got into my truck - been sitting overnight. Key on, no fuel pump pulse nor wait-to-start light for about 5 seconds, then the light came on & pump pulsed for about one second. The light stayed on for about 20 seconds then went out; truck started right up, fuel pump turned on & stayed on upon start-up. After pulling away from home a block or two the grid heaters had quit cycling. About a mile into my drive I shut the truck down & re-started about 15 seconds later (Ultra-Gauge reset). Key on and no pulse from the FP & no wait-to-start light; truck started right up. At this point the coolant temp was about 100-110 F, but after restart the grid heaters started to cycle again. I would have expected the heaters to stay off line. The other day I had taken a short drive but the weather was warmer & coolant temps were up to 180-190. Same thing; shut the truck down & restarted within a few minutes & the grid heaters were cycling. Hard to establish any pattern. I noticed with my Juice w/ Attitude that I can monitor fuel temp, I presume at the VP. Wonder if that parameter plays into the grid heaters being turned on. This morning it was reading 34 at start-up & got up to 79 after a 17 mile drive city/highway. Fuel pressure came up 0.5 to 1 psi over the drive. I will continue to monitor but won't take any action (like replacing the ECM) until it prevents reliable operation - keeping my fingers crossed. Joe in St Louis
Remember grid hater actions are based off of 3 sensors...
[*]ECT - Engine Coolant Temperature
[*]IAT - Intake Manifold Temperature
[*]BTS - Battery Temperature Sensor
Like on my truck I've seen this a million times. Run to New Meadows, ID and got a full head of temp 195* ECT. Then stop some where for like a soda shut jump out get your soda and fire right back up. Maybe shut down all of 2-5 minutes tops. The IAT and ECT and well above trigger point for grid heaters. But still the wait to start comes on voltage falls (grid heaters are active). Then after you fire up it pulsing grid heaters after your running again. The only reason I can see this occuring is the BTS being cold enough... Even in the FSM they mention that there is a relationship between the IAT and BTS sensors.
I don't recall the temp on 2nd gen's, (66°F for 3rd gens), but if the IAT is above that the WTS doesn't illum but if the ambient temp is low the grids will cycle after engine start. If the IAT is below the threshold the WTS will illum (time is based on temp), and the grids will cycle after the engine starts. In either case they will operate for up to 2 minutes or until you hit ~18 mph. I have no clue what the cutoff is for coolant temp (if there even is one on 3rd gens) as I have never seen it not operate from a hot truck.. just that 66° IAT number.
Thanks for the explanation, Mike. So the fuel pump is not tied into anything controlling the grids/WTS light - makes sense. I was not aware of a battery temp sensor; where is that located, in the battery tray(s)? Sounds like a tough environment.
AH64ID the :wts: will come on every time for a bulb check. It just do you see the voltage gauge fall or not. (Grids being active or not).
Driver side battery tray is the battery temp sensor. post-2-138698181425_thumb.jpg
Same on the 3rd gen up thru 05, no bulb check on 06+ if the grids don't fire.
Depending on the year the volt meter may or may not bouce with the grids. My 05 it stays low thru the entire cycle, but I can watch the volts change on my SG and in the headlights. My dad's 06 bounces with the voltage.
[ATTACH=CONFIG]3298[/ATTACH]
BTS plays no role in grid heater operation on a 3rd gen, it's only uses for charge rates.
This is out of the 01 FSM.
The BTS is used to determine the battery temperature
and control battery charging rate. This temperature
data, along with data from monitored line
voltage, is used by the PCM to vary the battery
charging rate. System voltage will be higher at colder
temperatures and is gradually reduced at warmer
temperatures
Well Dang... I'll have to find the document again about how the IAT is compared to BTS sensor at key on... I knew I read it somewhere but now I can find it... :banghead:
I decided to wire a custom relay system to power the lift pump where the relay is activated by a 12volt circuit from ignition system and is powered by alternator. I don't see a problem with the lift pump being power when the key is in the on position being that the pump has an internal regulator and if there is an over pressure situation the 14.2psi valve will open, relieving any pressure that would build if the regulator goes out. This would be very similar to bumping the starter and starting it half way through the cycle. Other than a good prime does anyone see a problem with this?
you will stilll be sending full pressure to the vp possibly causing hard starting. even when you bump the starter and start the engine during that cycle the ecm reduces the pressure for starting once the key is turned again. i believe it does this by cycling the pump on and off during starting. i have my AD connected to the alternator and plug into the wiring from the ecm to the old lift pump and when cranking i only see somewhere between 7 and 9 psi.
